I put a pair of Hyper-lites on the back of my 2010 FLHX. Fairly affordable and very small. I bought the license plate bracket from them and couldnt be happier. Dont notice they are there until you hit the brakes. They then flash four times and stay lit until you release the break. When not touching the break they are not lit. But there are lots of flashing options.
[url]http://www.hyperlites.com
Reason: pics
Yeah i put the tri-bar brake light replacement on mine. It makes those running lights on the tip of the fender a brake light. I think thats enough for me. I like that they removed the tomb stone tail light for the 2010s - never really cared for that thing much.
I bought the tri bar upgrade, but there were no installation instructions in the box. Do you know where I can find any instructions on how to swap the old one for the new tri bar brake / tail light? Thanks 2010 SG
I cant open the file, but maybe they will grant me access in the next few days. If you want you can try and send it here if you dont mind.
Remove the no spam *nospamRescueMedic1@tx.rr.com
Thanks
I'm looking at this upgrade. How much of a P.I.T.A. is it to install?
As soon as I can locate some instructions I'll let everyone know. I hope between that and the LED's on the airwing rack, that folks will be able to see me.
I switched out the stock for all LED front and back and it made a world of difference. I got them from Kurikyan and they are high quality and simple plug and play. I have the main tail light set up to pulse when I hit the brakes.
Note the bar in the middle of the tail light. It allow the left side to work with the left turn signal and same on the right. I'm very impressed with them and members of our chapter have had very positive comments and asked where to get them.
I was under the impression that you had to install a load equilizer when using the LED's. Is that not correct?
