Inner primary removal
Old Jun 25, 2010 | 06:36 PM
BLKBAGGER's Avatar
BLKBAGGER
Originally Posted by rocknrod
The only hard thing is getting to the starter fasteners from the other side. And thats not too hard.
Other than that? Cake.
A long extension and a swivel works great.
Old Jun 25, 2010 | 06:46 PM
DamnFool's Avatar
DamnFool
while you're in there - change out your tranny sprocket for a BDL lightweight one thats one tooth smaller. It will change your life!
Old Jun 25, 2010 | 07:03 PM
harry.b's Avatar
harry.b
I forgot to tell you that the only thing the manual doesn't tell you is to get a set of gloves when working anywhere around those cylinder fins. Those fins are sharp and when the bolts break loose, your hand could go flying into them and you might lose some skin. I learned the hard way with the intake manifold bolts. Now I put gloves on if I'm in the same room as the fins.
harry
Old Jun 26, 2010 | 07:47 AM
spiker's Avatar
spiker
Thanks again
Old Jun 26, 2010 | 08:06 AM
dougbk's Avatar
dougbk
Originally Posted by cuda67bnl
The inner primary has to come off to replace the shift lever between the trans and primary. There isn't enough room for it to slide off, at least not on my bike. I had to replace mine last year.
I had to replace the shifter shaft on my 89 and didn't have to remove the inner primary, so I ASSumed an 02 would be the same.
renlan
May 8, 2023 09:29 AM
miketv84
Jun 5, 2019 05:04 PM
streetglide13
Jun 22, 2014 04:20 PM
cajunKen
EVO
16
Mar 28, 2010 02:41 PM
skins71
Feb 2, 2009 09:58 PM
