Neck Adjustment???
Old Jun 25, 2010 | 03:44 PM
harleycat225's Avatar
harleycat225
Question Neck Adjustment???
Okay I got the manual and am going through it. Steering seems a little tight so I go to the chapter on neck bearing. It say to raise the bike and pull the bars back to the left stop and let go. Well when I do this it goes to center and stops. No swing to the right and back. Am I missing something here?????????????????? Manual says it should swing 3 times........
Old Jun 25, 2010 | 04:37 PM
paguy's Avatar
paguy
Before you touch the bearing. Get some high temp grease and fill the neck through the fitting.
Old Jun 25, 2010 | 05:20 PM
harleycat225
I still have grease coming out of the lower neck bearing from the 1000 mile service.
Old Jun 25, 2010 | 05:47 PM
boom23's Avatar
boom23
Mine does the same also but I have added heavier speakers, amp, and HID lights. So, the weight is different, which affects things...
I would be interested in what you find out.
Old Jun 25, 2010 | 05:49 PM
Thatzmister2u's Avatar
Thatzmister2u
Subscribed
Old Jun 25, 2010 | 06:00 PM
mongomark's Avatar
mongomark
Do you notice any symptoms while riding? Does the steering return to center? Does it alternate between pulling to the right or to the left? What are you noticing?
Old Jun 25, 2010 | 07:48 PM
DTTJGlide's Avatar
DTTJGlide
To do the test correctly you have to unhook the clutch cable & other things, read the instructions again & what are the symptoms as asked above.
cf7go
Mar 19, 2012 03:00 PM
Steel Wheels
Jan 30, 2012 07:00 PM
Talldog
Sep 24, 2011 02:28 PM
All Aces
Aug 20, 2010 09:35 AM
MikesWideGlide98
Jul 25, 2007 04:57 PM
