Re-Mapping..EFI tuning? DO it yourself?
Old Jun 26, 2010 | 09:24 AM
RACKnRAIL's Avatar
RACKnRAIL
I have a SEST on my bike and had it dyno tuned. The bike has never worked better and runs much cooler, I might add.
Old Jun 26, 2010 | 09:36 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
does not supercede, the pc only changes the signal that the ecm sends to the injectors. a canned map is the changes made.with the ecm already remapped the only way to know how much change is required is to dyno it,if its already on the dyno aditional changes could be made with the sert, no need for a pc,or u could uninstall the sert then use canned map with the pc, either system is only as good as whos making the map.
Old Jun 26, 2010 | 09:37 AM
bigdumbnoitall00
if the OP is happy with the existing tune a remap shouldnt be needed with just sdifferent slip ons.
Old Jun 26, 2010 | 05:34 PM
nvsteve's Avatar
nvsteve
Originally Posted by bigdumbnoitall00
the pc is programeed to make changes to a stock map his map is not stock.
If is map has the stage 1 remap you are not correct. There are maps from Dynojet that take the stage 1 map into consideration. Also, Fuelmoto will give you a map for stage 1 downloads.
Old Jun 26, 2010 | 09:05 PM
bigdumbnoitall00
IF the OP had stg1 download but he clearly states he has serts, what ever that is.
Old Jun 27, 2010 | 03:13 AM
hougz79's Avatar
hougz79
The OP would have to purchase a PCV. He already has the SE tuner. A change is slip-ons "should" not be significant enough if it's got a good tune. If not, run auto-tune. I respect the hell out of Fuel Moto, but buying a PCV when you already have a SEPST doesn't seem to make a lot of sense to me.
Old Jun 27, 2010 | 08:09 AM
ricaroo's Avatar
ricaroo
How about just calling Fuel Moto and ask them?
Rockitdude
Jul 4, 2018 03:33 AM
Flying low
May 20, 2014 07:25 AM
pargenz
Jul 24, 2011 03:53 PM
arcticrider
Jan 13, 2011 08:31 PM
AaronH
Jun 23, 2009 07:55 AM
