Re-Tune with Heavy breather?
Old Jun 27, 2010 | 01:14 AM
PistonPuller's Avatar
PistonPuller
Default Re-Tune with Heavy breather?
Currently have a 103 kit, Rinehart slip ons and SE air filter. Bike was dyno tuned with a SERT. I have been thinking about getting the heavy breather and wonder if I would need to spend the $300 to have it tuned again, or can I bolt it on and go with my current tune? This for a 2009 Street Glide
Old Jun 27, 2010 | 01:44 AM
flyingace's Avatar
flyingace
I went the opposite direction on my 09. Was told "not enough difference in airflow to matter between the two, don't worry about doing a retune".
Old Jun 27, 2010 | 01:47 AM
PistonPuller
Can I ask why you switched? Thanks for the reply
Old Jun 27, 2010 | 02:33 AM
hougz79's Avatar
hougz79
From what I've read (please correct me if I'm wrong) the Heavy Breather only makes a difference once you've eclipsed 100/100. If you are not there yet, you are "probably" ok.
Old Jun 27, 2010 | 10:34 AM
flyingace's Avatar
flyingace
I liked the look of the heavy breather, but after I mounted my tourpak permanently, I just didn't think it fit the look of a full on bagger. Looked great when the bike was more stripped down. Was nice to get the legroom back too. So it was just for cosmetic reasons.
Old Jun 27, 2010 | 07:05 PM
RK14SGS's Avatar
RK14SGS
Hey Bennie- you should be okay to ride, but I suspect you may need to re-tune, as more air will probably enter the air filter (like a ram air effect) at higher speeds; if so, the mix will be slightly leaner. Not sure by how much, or to what effect it will have (may be a 0.1 AFR difference; may be 0.5, or 0.9 etc, just not sure...) Do you have the newer racetuner (Pro) where you can use smartune feature? My dealer here charges $41 bucks to do a dyno pull; you may be able talk with the tech and see if they can alter the VE table while the bike is hooked up? worth a try...
Old Jun 27, 2010 | 08:35 PM
ucommbxny's Avatar
ucommbxny
you should not have a problem
Old Jun 28, 2010 | 12:54 AM
PistonPuller
Unfortunately I don't know where to take it because the local dealer here closed up shop. But there is suppose to be a guy around here that has a dyno machine and apparently rents out the machine for like $40 an hour. The only catch is he doesn't do any tuning, just rents the machine. I guess it's too much for liability ins. So it would be up to me. I have to admit I like the idea of doing my own tune, however I would really need to study the idea first. I have the pro super tuner #32109-08A
JeepnHD
Apr 30, 2012 06:40 PM
drgprov
Aug 29, 2011 12:57 PM
lfalla
Jul 14, 2010 04:24 PM
1 New Softail
Mar 7, 2009 07:04 PM
midnight2005
Feb 25, 2009 11:12 AM
