Ultra Limited 103"
Thanks,
Mike
When you add the bigger jugs to a 96, you get the 103 you would get if you added both the jugs and stroker crank to the 88.
The 110 takes it further, and I agree, thats a major tear down (like what doing a 103 to a 88 is/was) and I would not go there. (Id go to a 107 big bore kit with the stock crank first)
Be aware, the stock 103 in the Ultra limited, has the stock cams, and is pretty de-tuned compared to what you would get by doing an "after the fact" stage 2 hop-up. Don't expect the same power. Yes its a 103, but with tame cams, restricted intake, and a EPA (weak) tune.
