please help
Old Jun 28, 2010 | 09:01 PM
5 Speed Suicide's Avatar
5 Speed Suicide
Default please help
Just installed the fuel moto stage 1 on RG. Started up bike and have no throttle. WTF Anyone no why? PC V lights up and everything is connected.
Old Jun 28, 2010 | 09:06 PM
atrain68's Avatar
atrain68
These are the two things I'd check first.
Check the plug on the left side of the throttle body right behind the air filter. Is it plugged in? This is where the electronic throttle connects.
If that looks good then I would disconnect the harness from the PC V and reconnect. Make sure harness is connected and locked.
Old Jun 28, 2010 | 09:12 PM
5 Speed Suicide
ok I pulled the pv c and hooked up the stock connection and the throttle works. Maybe the PC V is junk?
Old Jun 28, 2010 | 10:03 PM
TexasTim's Avatar
TexasTim
Reconnect the PCV again and try it. If it still doesn't work then remove the PCV and call the FM guys in the morning. They will take good care of you.
RPS1981
Apr 1, 2012 06:58 AM
Canuckle
Jun 8, 2011 02:19 PM
Modee1245
May 30, 2009 02:02 AM
Eric in chicago
May 12, 2009 02:07 PM
RODEO
Feb 15, 2009 11:26 PM
