09 Ultra license tag bracket question
I was thinking of getting rid of the stock turn signal bar on my 09 Ultra and saw a Kurykayn turn signal kit that looked and good and also referred to a curved tag plate. I would like to do that too but it looks like the stock license tag bracket supports the tour pak.......is there anything out there to allow relocating the stock tag bracket to the lower part of the rear fender and still have the tour pak supported?
thanks to all
You can go two ways.
One way is with the complete kit.
Detachable Tour-PakŽ Rack Kit for Electra GlideŽ - '09-Later Models
Transform your Electra GlideŽ model for around town cruising. This kit includes everything needed to convert the rigid-mount Tour-PakŽ to an easy on-and-off detachable version. Complete kit includes two-up docking hardware kit, Detachable Two-Up Tour-PakŽ Rack, chrome strut covers, chrome license plate holder, reflector, and AM/FM antenna relocation hardware.
Fits '09-later FLHTC, FLHTCU and FLHTK models. FLHTCU and FLHTK models require separate purchase of Tour-PakŽ Quick Disconnect Harness for Ultra Models P/N 70032-09
53246-09A
$549.95
(This has a License relocation that just moves the mounting point of the plate to a different place. The license plate is still above the tail light.)
Or you can just get the rack and 4 Point Docking Hardware kit separately.
You would need to move the License Plate yourself. (Like the Kuryakyn kit you talked about.)
Detachable Two-Up Tour-PakŽ Mounting Rack
Change your riding style in less than 60 seconds. The ultimate in touring flexibility, this Tour-PakŽ Rack makes the convenience and protection of a Razor-Pak, Chopped, King, or Leather Tour-PakŽ Luggage System a simple on-and-off proposition. Simple turn latches mount the rack to the bike's docking points, and allow you to replace the Tour-PakŽ with a detachable sissy bar upright for around-town cruising. The chrome-plated Detachable Rack positions a Tour-PakŽ behind the passenger pillion, and allows the passenger to use the luggage as a supporting backrest. Adjustable over a 3/4" range, the Tour-PakŽ can be located for maximum passenger room and comfort. Tour-PakŽ, Passenger Backrest Pad, and Docking Hardware Kit sold separately.
53276-09A
$179.95
The ideal choice for maximum versatility, this complete kit contains the docking hardware necessary to install all Detachable accessory options. Even if you only install a passenger backrest today, this kit allows you to add additional accessories as your touring demands change. Provides docking points to allow installation of Detachable Sissy Bar, Solo Luggage Rack, 2-Up Luggage Rack, Solo Tour-PakŽ Rack or 2-Up Tour-PakŽ Rack.
54205-09
$149.95
(Note: You would still require separate purchase of Tour-PakŽ Quick Disconnect Harness for Ultra Models P/N 70032-09 if using the Tour Pak.)
