09 FLHX strange noise.
Old Jul 4, 2010 | 03:43 PM
banks727's Avatar
banks727
Default 09 FLHX strange noise.
Very strange. My bike recently started making a clicking noise when backing it up before starting. It's a very fast clicking sound that increases as the speed increases. Bike in neutral with clutch in. Anyone have anything like this?
Thanks
Banks
Old Sep 13, 2010 | 11:04 PM
chromedome's Avatar
chromedome
I'd be interested in the answer to this. My softail started doing this. Anyone?
Old Sep 14, 2010 | 12:27 AM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
Could be the drive belt rubbing the left edge of the rear fender near the front of the swing arm when the rear wheel is spun in the reverse direction.
Old Sep 14, 2010 | 12:43 AM
RKKY's Avatar
RKKY
My guess would be the drive belt as well. Make sure you belt guard is secured in the right position.
Old Sep 14, 2010 | 01:48 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
playing cards and a clothes pin?
sorry... i had to say it!
Old Sep 14, 2010 | 07:49 AM
navyman's Avatar
navyman
Had a similar issue, ended up being the IDS bearing in the rear pulley.
Old Sep 14, 2010 | 08:50 AM
Scorpion07's Avatar
Scorpion07
Best case scenario - Primary chain adjuster needs to ratchet up a tooth. Time will do it. I'm guessing here though....
Next - IDS bearing, although I'm not familiar with the design in the 09 wheel.
Next - Inner Primary bearing. Test - sound difference with engine running in neutral and clutch pulled in - out.
Worst case - Main Drive Gear bearing(s). Usually a vibration/noise while driving.
As far as the worst case goes, there seems to be a fairly low failure rate in 09's.
Although - the clicking is when I determined my Main Drive Gear bearing started failing. Good news with that - I rode 20K more miles after I first heard it.
Old Sep 14, 2010 | 08:56 AM
imrotton2's Avatar
imrotton2
dont go backwards
P51Driver
Mar 25, 2023 11:49 PM
jbielec
May 15, 2013 10:47 AM
juanbogrdo
Apr 19, 2011 11:24 PM
323bailey
Nov 30, 2008 04:24 PM
bud1
Aug 11, 2005 12:46 PM
