cycle smith apes
Old Jul 5, 2010 | 11:03 AM
stevesoftail's Avatar
stevesoftail
Default cycle smith apes
I bought the kit offered by Hill Country Cycles. 13" cycle smith bars with all the extentions and braided brake lines. Hill Country suggested that I change the handlebar rubber bushings for poly bushings. After the install, and every thing is tight, I have about 3/4 to 1" of back and forth movement at the grips. It could be from more leverage with taller bars. Has any one else with apes noticed this?
Old Jul 5, 2010 | 12:10 PM
Kevin's_09FXDF's Avatar
Kevin's_09FXDF
yes get the poly bushings and get a 1-pc. top clamp from harley. you will thank me later. its only like 50$ for both
i didnt buy these and now its all most unrideable. now i have to take the fairing off again to in stall these.
Old Jul 5, 2010 | 12:21 PM
PistonPuller's Avatar
PistonPuller
Not sure which bike, but my 09 already had a top piece. Are your bars only moving at the top end? the lower where the bars are clamped it not moving? With a 13" rise you will see a little movement due to the longer arm of the rise but should not see movement at the base. Mine do a little, but never noticed huge movement. Are they smiths or the hcc brand?
Old Jul 5, 2010 | 12:24 PM
Kevin's_09FXDF
Originally Posted by PistonPuller
Not sure which bike, but my 09 already had a top piece. Are your bars only moving at the top end? the lower where the bars are clamped it not moving? With a 13" rise you will see a little movement due to the longer moment arm of the rise. Mine do a little, but never noticed huge movement. Are they smiths or the hcc brand?
Being an 09 your bushes most not be worn out yet. on my 07 they are way to floppy. mine got worse over time. give it some time and yours will start to wear out.
Old Jul 5, 2010 | 03:28 PM
roadgliderick's Avatar
roadgliderick
i have a 09 streetglide with 16 in. cyclesmiths and have been on for over a year and no issues with movement. some but very little. and i have over 20,000 on my bike.
cggorman
Sep 26, 2019 08:18 PM
L B
Aug 27, 2018 11:03 PM
maryvillept
Jan 24, 2013 04:41 PM
bluelinerider
Nov 18, 2010 11:32 AM
lowrider284
Mar 22, 2009 09:28 PM
