Alarm Chirps?
Old Aug 27, 2006 | 04:06 PM
ibridin's Avatar
ibridin
2nd Gear
Default Alarm Chirps?
My alarm has just started chirping 3 times instead of the usual 2 times. Any ideas as to what can cause this?
Old Aug 27, 2006 | 05:02 PM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
Default RE: Alarm Chirps?
This means that the battery in the siren is about to die. Order the replacement battery kit from HD. The 3 chirp is designed to tell you if the battery is low or has been trying to charge off the main bike power for more than 24 hrs. The kit will have a battery and new door that will seal properly because you have to break the seal on the original door when you replace it.
Old Aug 27, 2006 | 05:13 PM
ibridin's Avatar
ibridin
2nd Gear
Hi Thanks for the reply! I did change the rechargable battery in the siren. It chirped two times until I rode the bike for a liitle bit, then started chirping three time again?
albertasaurus
Oct 5, 2022 02:52 PM
albngore
Jan 6, 2016 05:54 AM
JayOhh
Apr 17, 2013 12:02 PM
Deuceandahalf
Jul 1, 2010 09:09 AM
hdlowryder
Nov 12, 2007 08:34 PM
