1 gallon left gas light???
Old Jul 12, 2010 | 10:34 AM
  #41
SUPRPIG's Avatar
SUPRPIG
I tried mine out when first purchased and was amazed it worked as well as it did. It let me know when I was on reserve, then switched to the remaining mileage. It worked perfectly although remaining mileage was a little less then originally indicate. Don't like to press my luck and usually look to refuel when it gets between 1/4 and 1/2. Getting off feels good as a side benefit.
Old Jul 12, 2010 | 10:40 AM
  #42
shortride's Avatar
shortride
Originally Posted by SoCal RK Rider
I just bought a 2010 FLHRC that has a 6 gallon tank,, I have never fueled up before the light has come on and it regularly takes quite a bit less than 5 gallons.Like closer to 4???? The whole reason for a larger tank is more distance between fueling up. Does it really hold 6 gallons?Di I need to keep trickling in the gas until it is half way up the nozzle cut out?
How much does your Road King take once the light comes on?
Thanks...
Had you rather the light come on when you're almost out of fuel? I like it coming on with a gallon left. If you know about how many MPG you get it should be fairly easy to estimate how far you can go after the light comes on. I've actually stopped for fuel within a mile after the light comes on and put 4.6 to 5.2 gallons in the tank. It also depends on how full you get the tank.
Ohboi707
Apr 28, 2014 03:51 AM
WhiteNoise
May 25, 2012 03:00 PM
BowlinBiker
Jul 7, 2011 11:08 PM
jdsmitty10
Jun 10, 2009 08:14 PM
06BlackFLHXI
Apr 22, 2006 10:14 AM
