Dealer Changed their mind now....
Old Aug 28, 2006 | 02:53 PM
bucs012's Avatar
bucs012
Default Dealer Changed their mind now....
I bought my 07 RG and the dealer said..."oh, no need for us to re-map the bike if you put on different mufflers". Even if they put on Sream'n Eagles.
Well, now I have put on the reworked mufflers from B&E (mufflers only which are 06 Harley Mufflers with 2" baffle) and now the Dealer says "oh ya, we'll want to flash that for $150."
I just changed mufflers. No pipe or air cleaner changes done...........What the hell?
Old Aug 28, 2006 | 02:58 PM
gunrunner's Avatar
gunrunner
Default RE: Dealer Changed their mind now....
check your plugs, if they are light tan or grey, and its running good, forget it, if not, then its your call, but the new 07 updated efi system w/02 sensors is said to remap itself for a simple muffler change.
Old Aug 28, 2006 | 03:55 PM
bucs012's Avatar
bucs012
I know what a fouled "rich" plug looks like. What does a "lean" plug look like? I pulled mine with my stock mufflers and 700 miles and the plug was a light grey/white color. I thought that's what a "lean" plug looked like............
Old Aug 28, 2006 | 04:07 PM
Shovelhead Bob's Avatar
Shovelhead Bob
ANY changes to the system and you MUST change the map.....
It is a CLOSED LOOP, which means the ECM is monitoring BOTH ends of the process (Intake and Exhaust).......
The lack of backpressure will enhance a lean condition.....
The color of a plug anymore is irrelevant on a FI motor.......
I have tuned bikes that had a 13.8 AFR and the plugs were white as snow and very little residue.....
Those o2 sensors need to have the exh gas' in the pipes to monitor and adjust to a STOCHIOMETRIC value, which modifies the injector dwell and spark table....
Without the adequate backpressure, the sensors are doing triple time to keep up with the apparent need, and no more air to add to fuel, so it only adds a small amount of fuel...
Don't do a half-azzed job, do it right and apply the SEAC and SERT to get the muffs to sound like they are supposed to....
You are still pulling the same amount of air with the stock AC unit, and mufflers work on a principal of using MORE AIR to make their power and sound.....
Are you tracking?
Old Aug 28, 2006 | 04:08 PM
gunrunner's Avatar
gunrunner
A lean plug will look white, the whiter the leaner, light tan or light grey is what you want.
Old Aug 28, 2006 | 04:23 PM
Bruce00's Avatar
Bruce00
Great to see you back SH Bob
Might as well do the air filter before you remap the bike bucs012. remember the motor is nothing more than an air pump...........air in--air out
Old Aug 28, 2006 | 04:43 PM
HD Renegade's Avatar
HD Renegade
ORIGINAL: Bruce00
Ditto - Just what Bruce said.
Bob
Old Aug 28, 2006 | 06:28 PM
Capt.Bob's Avatar
Capt.Bob
All that being said. Should the exhaust pipes get cherry red under the heat shields? I mean glowing red enough to look like lights shinning on the chrome parts of the motor at night.
http://bobbyhill.home.att.net
Old Aug 28, 2006 | 06:47 PM
gunrunner's Avatar
gunrunner
they will close to the head.
Old Aug 28, 2006 | 07:26 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I'd get a PCIII usb from eastern Performance, or some other quality vendor and install it mysely with a map from the website.
it is more than the dealer is going to charge you for the flash BUT
that way if you want to add a SE or Ness air cleaner at some point, you can remap it yourself.
And what is this 150 bucks to flash the ECM.... the data is probably free to them, and it takes nothing to do it.
talk about whan you have them by the ***** thier hearts and minds will follow.
