Dumb question
Old Jul 14, 2010 | 12:11 PM
QIKLUV's Avatar
QIKLUV
Default Dumb question
just curious... is there a way to remove the left grip without destroying it? looking at new bars and my grips are only 8 months old.
Old Jul 14, 2010 | 12:15 PM
bradsULtd's Avatar
bradsULtd
Just do a search and you will find:
https://www.hdforums.com/forum/touri...ving+left+grip
Old Jul 14, 2010 | 12:19 PM
Ronp42's Avatar
Ronp42
Account Retired
Yes, If it's the stock rubber grip, take a thin blade screw driver and pry the front edge up enough to squirt some solvent under it. then start twisting it back and forth to break it loose. I've used lighter fluid with good results. Wd 40 will work.
Old Jul 14, 2010 | 01:20 PM
isac's Avatar
isac
A blowgun and compressed air, just put the nozzle under the grip and it will fly off in notime..do the same if you want to change the rearbrake rubberpad also.
Old Jul 14, 2010 | 01:27 PM
QIKLUV's Avatar
QIKLUV
thnx for the help guys... WO575 here i come
Old Jul 14, 2010 | 01:40 PM
moondog99's Avatar
moondog99
Correct. I also once I pry it up I spray a little WD-40 to aid it along. Works like a charm.
Old Jul 18, 2010 | 09:31 PM
QIKLUV's Avatar
QIKLUV
what would you guys recommend.. what clutch cable and brake cable.. some say you can use the stock. but i don't want to push it... do it right the first time..
Old Jul 18, 2010 | 09:33 PM
dawg's Avatar
dawg
The 38649-08 clutch cable should work with the 575's.
Old Jul 18, 2010 | 10:03 PM
QIKLUV's Avatar
QIKLUV
the DAWG come thru once again
Old Jul 18, 2010 | 10:07 PM
QIKLUV's Avatar
QIKLUV
so the brake hose should be OK? with some tweeking?
