I am not sure if I agree the 940's would be the proper choice. A 300 pound rider with 140 pound passenger probably doesnt need the rear of the bike lowered any. The information I had was that the 940 was shorter than the stock shock and would result in lowering the rear, thus reducing ground clearance.
I think his best choice would be any that are the 13" length, just a better quality than stock.
I'd suggest foregoing the Progressive's all together and get a set of Suspension Technologies shocks. All of their shocks are individually made to the rider's riding style and dyno'd to ensure that they perform the way they are meant to.
Everyone that I know that has them says they will never go with another brand.
MSRP they run $490-$545 but you can get them for $441-$531 if you do some digging.
How much for each that i have mentioned? 412? 430? 440? 940? why 940's best? why not 412's?
I suggest you contact Drew direct with that sort of question!
However as the others point out there are alternative shocks available. I have Ohlins from HDF sponsor Motorcycle Metal, which have cured all my rear suspension woes.
i had the 412's on my superglide. i weigh 170 lbs. i ordered them with the standard spring. i had to keep the preload on the highest setting because the shocks would bottom out over small bumps. i then ordered the heavy springs for them and put them on- same result. I then ordered a new set of the 440's with the heavy spring and it was better, but over larger bumps it would bottom out. to say the least the stock shocks worked better. progressive shocks seem to have a problem when going over manhole covers which tends to bottm them out.
Here is my personal experience with the 440's. Bought the heavy duty model and found them to be "way" too stiff. Sent them back to Progressive and they resprung them with softer springs. Still way too stiff. They launched me off the seat on larger bumps. They were so stiff the wife refused to ride with me. Took those off and bought new OEM shocks. Happy as a clam!! The wife now rides again.
Personally, I believe if you are a big boy (225 lbs or more) the 440's will work for you. However, if less than 225 lbs......start looking for a good chiropractor!!!
