PCIII Trouble
Old Jul 17, 2010 | 12:36 AM
Jukebox's Avatar
Jukebox
Default PCIII Trouble
Ok guys I need some info. I installed a PCIII back in Jan. and so far I have been happy with the results. Monday the wife and I were on our way down to the Hill Country for a few days. We had been on the road about an hour and a half when my bike started cutting out like I was running out of gas. I had half a tank so I knew that wasn't it. I pulled over,checked the PCIII and noticed that the green LED'S were not lighting up when I turned on the ignition,then the bike would not even start(like it was out of fuel)so I bypassed the PCIII and the bike started right up. Went on my trip no prob. I came home,plugged the PCIII up to my laptop and the LED'S lit up and did thier thing. I re-loaded the map(just for good measure)went outside and plugged the PCIII into the bike and it started right up. Has anyone ever had any problems like this? I was wondering if maybe it just got to hot or something? HELP!!!!!!
Old Jul 17, 2010 | 06:00 AM
Jinks's Avatar
Jinks
Any chance you had a loose connector?
Old Jul 18, 2010 | 12:11 AM
Jukebox's Avatar
Jukebox
I checked the connections,but anything is possible. Someone told me that it sounded like a ground problem. The thing is I have only had it on for 6mos and never a problem,and I can't find the reciept for it in case it is something worse. I am going to reinstall it tomorrow and see what happens. Wish me luck.
Old Jul 18, 2010 | 12:19 AM
drukanfu's Avatar
drukanfu
Yep, sounds like a ground problem.
Old Jul 18, 2010 | 05:56 AM
Jinks's Avatar
Jinks
A loose ground is certainly a possibility, but it would still be there even without the PCIII (& just as intermittent). If you continue to have problems I'd certainly look for a loose ground. In the mean time, when you re-install the PCIII tie wrap the connectors tightly together to prevent any loose connections.
gevange
Softail Parts
Mar 4, 2014 09:38 PM
fsnco
Mar 19, 2009 10:02 PM
07stglyd
Dec 13, 2007 05:54 PM
swipter
Nov 4, 2007 07:56 PM
Sleeps In Trees
May 23, 2006 10:48 AM
