Leaky Fairing
Old Jul 20, 2010 | 12:23 AM
GPHarley's Avatar
GPHarley
2nd Gear
Exclamation Leaky Fairing
My 2010 Triglide gets water inside the fairing when I wash the bike. 2 weeks later when I ride water will come out of the bottom of fairing when in a sharp turn.Harley dealer said it was normal and not to worry about it . Harley,s customer service said the same.Is it normal to get water in fairing and could it cause problems in the radio and gauges later.
Old Jul 20, 2010 | 04:36 AM
relli's Avatar
relli
happens to mine.
Old Jul 20, 2010 | 05:30 AM
agapsdiver's Avatar
agapsdiver
My brother had it happen to him last month on a trip up to Sturgis....
half way thru the first rain day his head light went out... he had over an inch of water sloshing around the bottom of the headlight.
Old Jul 20, 2010 | 06:28 AM
JimTJr's Avatar
JimTJr
If your saying that it sits in there and stays there,,, I don't know where,, and this is the first I have heard of it. BUT would a good solution be to drill a very small 1/8" or so, unobtrusive hole to let it drain be an idea?
Just wondering...
Old Jul 20, 2010 | 12:20 PM
agapsdiver's Avatar
agapsdiver
Just wondering...
yep.. he has a 2006 EG.. and it was an inch of water in the head light...
just sloshing around...
Old Jul 20, 2010 | 01:04 PM
No Tyme's Avatar
No Tyme
I agree with you; it seems as if would cause problems down the road if not sooner. I myself will change out a rubber seal that is on the inside top of the fairing. As a tester for LRS I have changed out windshields and had my radio serviced, installed an oil temp gauge, Hog tune speakers as well as sound proofing material on the inside of my fairing, so it has been on and off more than I would like to admit.
I know the fitting of the fairing can be tricky getting it just right...
I would be concerned about any water inside my fairing.
Old Jul 20, 2010 | 02:25 PM
SG 1's Avatar
SG 1
2 weeks sounds like an awfull long time for water to stay inside a fairing. Seems like it would evaporate before then.
Never happened on mine and doesn't sound normal to me.
Most likely place for it to come in would be around the w/s. Have you changed it?
Old Jul 20, 2010 | 05:42 PM
Fathead2003's Avatar
Fathead2003
Not normal on my ride 03 EG Standard.I have had my fairing off several times over the years. Had ridden home all day in rain and have never had water in my fairing that I have known about. I would be very concerned about corrosion if the water was in for 2 weeks. Check your rubber seals. I did have a windshield bag that vibrated so intense the center brass insert that the fairing screws go in started moving pulling out causing a opening at the top of the fairing. I caught it in time before water entered. Superglued it back into the inner fairing and got creative with and alternate bag mount.
Old Jul 20, 2010 | 06:19 PM
2WheelGlider's Avatar
2WheelGlider
I have had my fairing off several times and cant see how it would hold water, I must be missing something. Since a trike never really leans over, I could see that it would hold water when a standard bike would not. I think I would have to drill a small relief hole at the lowest point to resolve the problem. HD is correct, its normal, all until the warranty runs out and its on your dime to fix it.
Old Jul 20, 2010 | 09:41 PM
Wonderbob's Avatar
Wonderbob
Just wondering...
+1. Hi Jim I lke your new quote!
hanny
Oct 25, 2013 10:49 AM
BLK08ROCKERC
May 7, 2013 07:32 PM
The Dude
Audio Systems
Mar 3, 2013 06:43 PM
vinchenz07
May 2, 2008 12:28 PM
monkish
May 19, 2007 07:44 PM
