Tachometer not working
Old Jul 25, 2010 | 08:09 PM
Potato_Potato's Avatar
Potato_Potato
Default Tachometer not working
Helping a friend with a 2005 Deluxe who's tach is not working. I posted on the Softail forum with no response. I searched and looked in the SM with no results.
What could be the possible causes? A sensor? A fuse? How could I trouble shoot this?
Old Jul 25, 2010 | 09:07 PM
07RoadHawg's Avatar
07RoadHawg
I'm assuming it's an aftermarket tach? If so, does it light up? If not, it's likely gotten a short somewhere and blown the fuse that it taps in to for power or a bad ground connection.
If it does light up, I think it would most likely be the signal wire. I'd bet the ecm is still sending the signal and that it would be a bad wire or connection.
Old Jul 25, 2010 | 09:15 PM
Potato_Potato
I don't have the bike here to look at he's bring it over in the next couple of days. As I recall its a Harley tach mounted near the risers. I will check for fuse, bad ground, etc. Thanks.
Old Jul 25, 2010 | 09:18 PM
07RoadHawg's Avatar
07RoadHawg
Yeah, the other option is the speedo/tach combo unit. If it's the same as the '07, there will be 3 wires. Orange/white is +, black is ground, and pink is the signal and should be secured in the plug on the back of the speedo.
BrianK
Feb 15, 2022 07:53 PM
sodbuster
Mar 26, 2013 02:29 PM
Thierry
Feb 24, 2011 02:11 PM
ericsenf
Nov 19, 2007 09:11 AM
HDV2
Oct 28, 2007 11:53 AM
