LED Tourpak dilemma
Old Jul 26, 2010 | 11:39 AM
davidw221's Avatar
davidw221
Default LED Tourpak dilemma
Man do I have a dilemma, I recently wrecked by bike, so during the repair, I decided to put a tourpak on it.
So I had the Tourpak painted, NO problem, the paint is great, matches perfect.
So I decided to get LED lights on the Tourpak, an purchased them through Custom Dynamics, so here lies the problem, the owner of the bike shop says those lense lights are glued to the Tourpak therefore there very hard to remove without damaging the new paint.
I know nothing about the Tourpaks and how they work, dummy me!
So Can they be removed without any issues, or am I screwed?
Secondly, how are you suppose to replace the bulbs if they go out, from the inside?
I really want the LED look and am looking for direction to get this done.
Thanks guys.
Old Jul 26, 2010 | 11:52 AM
Garemlin's Avatar
Garemlin
Are you talking about the side marker lights??? They aren't glued in. At least they aren't supposed to be. They attach with two screws from the inside of the tour pak.
Old Jul 26, 2010 | 11:55 AM
davidw221's Avatar
davidw221
NO, I'm talking about the rear lights on the Tourpak.
Old Jul 26, 2010 | 11:58 AM
Garemlin's Avatar
Garemlin
Dunno exactly what LED setup you bought. But most are LED replacement clusters that replace the bulbs. Pop the lens off and replace.
Old Jul 26, 2010 | 12:01 PM
41inWV's Avatar
41inWV
You can remove the bulb sockets from inside the tour pak, then take a rod about 10 - 12 inches long and about 1/2" thick and insert it through the socket hole and GENTLY push the lenses out (they are held in with an RTV/Silicone 'stuff') set them aside WITHOUT touching the 'sticky stuff'. Plug your LEDs in then carefully press the lenses back into place. There are like two little tabs on the lenses, one top and on bottom I think that you need to carefully unseat and then reseat.
Old Jul 26, 2010 | 12:02 PM
Scorpion07's Avatar
Scorpion07
I was contemplating their LED's myself, and read their directions online. It looks as though the lens itself is glued on with some flexible adhesive (from the outside). I don't believe you have to remove the entire light bar.
I could be mistaken - it's been a while since I looked it over.
Old Jul 26, 2010 | 12:03 PM
KoalaCowboy's Avatar
KoalaCowboy
The HD "LED light package" replaces the standard light package on the Ultra Tour Pak and has a couple of screws that connect on the inside of the TP.
Not sure 'how' the Custom Dynamics LED pkg works. Might be a good idea to call Custom Dynamics and get the skinny straight from the source.
Old Jul 26, 2010 | 12:22 PM
UltraClassicElectraGlide's Avatar
Part number is RTV Silcone Sealer / #99710-88
Old Jul 26, 2010 | 12:48 PM
Olde Skool's Avatar
Olde Skool
I installed Ridetime Technology LED's in my Tout-Pak. I did not use any additional sealer, or at least that is what my feeble memory recalls...Here is a link to the instructions to remove them. Pick the one that works best for you!
http://www.ridetimetechnology.com/installation.htm
Old Jul 26, 2010 | 12:52 PM
shortride's Avatar
shortride
Thanks guys.
Don't know what model scoot your talking about but I think you need a load equalizer when installing LED's.
