Checking air in rear tire... Any Tricks??
I've never been very good at checking tire pressures and it's one thing I've tried to focus on to get better at. Those tires are a pretty important part of the cycle. :-)
Thanks for any tips or just making fun of me for this post.
T
H-D sells an air guage with a hose and 90-degree valve for $30, this may be your best option - or find a guage with 90 degree valve someplace. Adding air is even more difficult because I can't find an air chuck with a 90 degree tip so far. I'm barely able with some effort to get it filled with a regular chuck that has the usual angle to it, but this requires some effort (pushing/flexing the rubber stem outward a bit with a finger from the other side while engaging the air chuck on it).
I plan to go with the 90 degree air valves on the wheels NEXT tire change, but that's gonna be several months yet at least as they have a good amount of tread left on them. This will allow much easier access with even a straight air chuck.
This, easier to just lay on the ground than to take the bag off.
In the middle, a piece of hose from a manual air pump with a plastic stem lock, and a tubeless valve stem on the other end (not my idea, I got this from a member) this tool, and a small air compressor can be a life saver and is perfect to take along on the road. I paid a few bucks for this air pump many years ago at Wal-Mart, not knowing it was going to be so useful, lol.
On the bottom, a cheap digital gage from Radio Shack, but its sold by many stores under different brands. Its shape and size makes it very easy to stick in between the disk and the hub to check pressure, just as easy front or rear. Very accurate too. Check out pic #2. Its on the front wheel, but I can use it in the rear wheel, with the scotter on the sidestand, without removing the sidebag. But nothing beats the little extension in the middle for versatility, whether checking air pressure or inflating the tire.
Regards,
