dead short
Old Jul 30, 2010 | 12:37 AM
skonarske425's Avatar
skonarske425
6th Gear
Default dead short
my 96 E-glide developed a 7.3 volt draw off my new battery after overhaul to top end. Have gone through unhooking everything. Connections, fuses, ground wire connections cleaned. took it in and had stator replaced, regulator, fuel pump relay. Finally unhooked the ECM relay and lost the draw. Replaced the relay and back it came, all -7 volts. Any help please on where to look. bike runs w/o engine light coming on? But idle drops way off too. Any help please.....
Old Jul 30, 2010 | 12:52 AM
2nd Mike's Avatar
2nd Mike
Check out all of the wiring of the sensors connected to the ecm.
Disconnect the ecm,go to each sensor,disconnect the plug,connect one end of an ohmmeter to ground and probe each terminal of the plug with the other(not the sensor itself!).
You should NOT get a reading if the wiring is OK since there's nothing hooked to it on either end.
If you do register a reading,there's your problem.
Trace the wires looking for a smashed or bare wire.
Old Jul 30, 2010 | 09:03 AM
skonarske425
6th Gear
thanks I will try that much appreciated
Old Aug 1, 2010 | 11:35 PM
skonarske425
6th Gear
Well I tried. No readings. Still got the dead short. I have tried everything??? There is a short somewhere. Just can't get there!
Old Aug 2, 2010 | 08:32 PM
skonarske425
6th Gear
I went back and retested my temp. sensor. got .5 ohms with ecm unhooked. Is that enough to be the problem??
Old Aug 3, 2010 | 12:57 AM
lakeman's Avatar
lakeman
giving you a bump .... please post the fix when you locate the problem.
ColinLarrisson
EVO
21
Jun 8, 2015 09:34 AM
Stick_Drifter
Jul 25, 2013 01:13 AM
BFJR
Jul 16, 2013 12:13 PM
weldking888
Shovelhead
Jun 21, 2009 04:30 PM
chazreid
Ironhead
Jul 7, 2006 01:52 AM
