Ground Wire
Old Jul 25, 2013 | 12:58 AM
Stick_Drifter's Avatar
Stick_Drifter
6th Gear
Default Ground Wire
Having some charging problems guys...I was checking connections and noticed that the ground wire was melted down to the copper wires would this cause a charging problem?
Old Jul 25, 2013 | 01:01 AM
LightningRider's Avatar
LightningRider
6th Gear
I can't open attached images for some reason but yes melted ground would indicate a loose or dirty connection causing arcing which will definitely affect charging and will lead to stator/regulator failure if not corrected.
Old Jul 25, 2013 | 01:13 AM
Stick_Drifter
6th Gear
I'm going to replace the cable tomorrow was just wondering if this was the problem.. the other day I went on a 70 mile ride and when I went to start it back up the battery was drained and it kinda gave a little problem before I went but I figured the ride would charge it up
BFJR
Jul 16, 2013 12:13 PM
skruzluce
Sep 21, 2009 07:11 PM
weldking888
Shovelhead
Jun 21, 2009 04:30 PM
sewers
Sep 25, 2007 09:12 AM
chazreid
Ironhead
Jul 7, 2006 01:52 AM
