Which Stator
Old Aug 1, 2010 | 11:27 AM
PDDGM's Avatar
PDDGM
Default Which Stator
I have been checking the motorcycle parts websites, and there are two stators/rotors( 32 amp and 45 amp) listed for 05's HD Touring
Does anyone know which one is used on a 05 Ultra?
Joe
Old Aug 1, 2010 | 11:41 AM
bikergeoff's Avatar
bikergeoff
An 05 Ultra has the 45 amp stator, but I highly recommend changing over the entire charging system to Cycle Electric's 50 amp charging system. The kit comes with rotor, stator and voltage regulator.
Old Aug 1, 2010 | 11:42 AM
PDDGM's Avatar
PDDGM
Thanks, wonder what that would cost, and if it's a coversion I could do myself. Also, I see there are three phase kits, are these any good?
Joe
Old Aug 1, 2010 | 12:05 PM
bikergeoff's Avatar
bikergeoff
The three phase kit is what I went to on my 01 Ultra. The whole kit ran me almost $400 through a local indy near Detroit. If you feel confident in some basic wiring and pulling your compensator sprocket and primary chain, it's a pretty easy job. I did mine myself, it took about 3 hours. As long as you've got some mileage on your bike, the primary chain should have enough slack that you won't need to pull the clutch hub.
Old Aug 3, 2010 | 10:55 PM
PDDGM's Avatar
PDDGM
Ok, my indy is suggesting to put on a new stator, rotor and regulator. Not sure if this is the 3 phase system or not. Have to talk to him tomorrow, working midnights and haven't really gotten to talk to him about it. My question is this: If this is not the 3 phase system, is it necessary to put on a new rotor and regulator knowing the stator tested bad? Price is around 400.00 for the parts and then labor. I ain't cheap, but don't like paying for things that may not be needed...
Joe
Old Aug 14, 2010 | 12:38 PM
PDDGM's Avatar
PDDGM
UPDATE: I picked the bike up this morning from Biker Alley at Osage Beach, Mo and must say I was almost in shock at the bill. 1- Cycle Electric stator, 1-primary chain adjuster shoe, 1 qt oil, 1 primary gasket and labor. Total bill
$273.94. He also adjusted the clutch, bled and refilled front brake fluid. I am totally in shock, was expecting 350-450.00 bill.
Joe
jim h
EVO
27
Jul 1, 2017 09:02 AM
elev8rguy
EVO
16
Sep 4, 2012 10:30 PM
mbierbac
Feb 15, 2012 11:56 AM
cfd37buckeye
Aug 9, 2011 06:07 AM
HDF Tech
Electrical/Lighting/Alarm
Jun 27, 2005 08:46 PM
