Se 120r complete engine?
It looks on paper like those heads are way to big to support a cam swap in hopes of getting more low to midrange tq. I'm sure that monster cam it comes with is better suited to those heads. Sounds like a very interesting package. I'm already trying to talk my Dad into one. LOL
Zach
I'm glad that I never have the $$ when something just gets released. It gives me the time to see what kind of bugs are in this thing and for the developers to work them out. And don't forget the "R" stands for "RACE"
Oh ya GRH said they developed this motor for a new drag class .......Baggers It will be cool seeing baggers turn 8-9s in the quater
Zach
First of all you know a lot.
This shouldn't be a mystery motor to you. Remember the SE 120R kit that had the cases bored wrong, that you and your buddy found? HD even put out a memo on it that I sent you? Same engine only assembled. I even thought about having your buddy assemble it, but the distance made it cost prohibitive.
I don't mind going first either. I'd rather of been part of the Apollo program and went to the moon instead of waited for technology to improve and taken a ride on the space shuttle Challenger.
Afa blowing it up, I have HD backing me on a side bet. Most people won't get a deal like that. Most builders wont give tgat deal either.
Thanks for the heads up on the exhaust. I'll order it tomorrow. Do I need a certain type baffle? What wiuld happen if I kept it restricted and quieter? Just less power?
This is all fun to me, no offense meant.
Best regards
I never said it was an 120R, I said it was one of the new HD 120's. It may or may not (more than likely, NOT) be the same. THe posts I've read both here and on other forums are certainly entertaining, if nothing else.
For the record, I have not had one of the HD Christmas Catalogs in at least 5 yrs, so I do not know what the "official claims" are. I do know from the scanned dyno graph on the other site that 108 ~ 109 ft/lbs of torque @ 3k RPM, on a hot motor as big as a 120 is mediocre at best. 140+ HP is more than respectable, if you wanna drag race the bike.
I've built dozens of 103 & 107" motors that have more torque than that, in the RPM range that most people ride, 99% or the time. Heck, my HQ98" motor made 111 ft/lbs @ 2250, and held it all the way til 5k+, and that was on a 10:1 static CR build ~ a 98" build.
One other thing on that marketing hype dyno sheet... it is showing over 140 HP. If I understand what folks are saying about these motors, that's what ya get when you use the 12:1 pistons, this new "Hurricane" head (probably bigger ports & valves than the already too big configs of their predecessors) & .700 lift cam. ARE YOU F'ING KIDDING ME? That's not gonna be a motor you can cruise or tour on. As fuel quality continues to decrease and more crazy additives are introduced, a 12:1 motor is gonna be hard pressed to survive ~ just think about how often folks are complaining about heat, pinging, & hard starting on the basic 96 or even 103" late model Twin Cam....
It'll be a novelty, no doubt. As far as a good motor for the avg Bagger Guy.... Not likely. Time will tell. If I'm wrong, I'll gladly admit it...
In answer to your question about baffle(s)... If you are seriously considering build a motor like this, you may was well use the Boarzilla with the standard baffle. That motor is obviously designed to breathe.
One other thing for those "wow'd" by the "dyno sheet". REMEMBER, a dyno sheet is really far more valuable as a marketing tool (working quite well, in this case) than as a representation of how a motor will or will not run & ride. Just because a sheet shows BIG numbers, it does not necessarily mean that the motor will run or "ride" well. It's a snapshot of a WIDE OPEN (WFO) throttle run. It is no indication of rideability whatsoever.
Please check post #22 of this thread. It gives a link to info and dyno on the motor. The dyno looks nice to me, but didn't sell me. Many factors did.
Mainly I wanted a big motor I could afford and if something went wrong, the culprits were near by. I have that here.. My dealer will stand behind this. Why? Because I spend lots and have friends. There are at least 5 dealers within easy driving distance aching for businesses. Enough said.
I have a lot more to say but I have to type in binary code with my phone. It takes for ever.
If I beat 1 Ninja 600 from bar A to bar B and blow it up pulling into the parking lot, all real bikers should applaud my efforts.
The guy's "friend" didn't have the crate motor. He had the complete assembled kit.
