Se 120r complete engine?
Isn't anything in the 100-120 ft/lbs more than enough in the 1800-3250 range for a bagger. More than this is just extra wear on the transmission and tires.
Pushing the extra torque and hp up to the 3250-7000 range gives the rider the ability to be more selective of the power use.
Someone please explain why I need 135+ ft/lbs of torque at 2000-3250 rpm. It seems to me the torque curve on this cam would be beneficial to the logevity/reliability of a sanely ridden bagger.
I have a TC88 Dyna with stage 1, which I only ride solo, and on which I have reduced overall gearing from the stock 25T compensator to a SE21T. That increases torque to the rear wheel by 19% over stock and gives wonderful performance for very little outlay. If we assume that bike gives around 80 ft.lbs TQ at the crankshaft, with my revised gearing of 3.75:1 (compared with factory 3.15:1) torque at the rear wheel is 300 ft.lbs (80 x 3.75). If we now take my weight plus that of the bike into account (180 + 670 = 850 pounds, or 850 / 2000 = .425 tons), we get a torque to weight ratio of approx 700 ft.lbs/ton (300 / .425).
Now let's turn to my dresser. With my wife on board and the bike fully loaded, ready to start our annual summer tour, I reckon our rolling weight is close to 1200 pounds, or .6 tons. The gearing on that bike is 3.37:1. So if I want my Glide to give similar performance when 2-up as my Dyna gives when solo, I need the same torque to weight ratio of 700 ft.lbs/ton. We have to reverse-engineer the above sums, so torque required at the rear wheel is 700 x .6 = 420 ft.lbs (compared with 300 for the Dyna). Torque at the crankshaft is 420 / 3.37 = 124 ft.lbs. In 5th gear on a 2011 bike, those figures are 420 / 3.407 = 123 ft.lbs.
Now that may not be 135 ft.lbs, but is not far short of it! If you want to whip a solo Harley while 2-up, or just enjoy some serious performance, you need a serious injection of torque. A few of us fall into that category!
Nothing less than a 131ci will do....
Now math I can understand. Thanks that helped.
I changed the clutch basket gear instead, to fix the stock "too tall" gearing issue. No regrets, but guys are also accomplishing the same thing with the trans pulley swap.
