Average MPG
Old Aug 4, 2010 | 01:24 PM
  #31
oldbagr's Avatar
oldbagr
I average 38 when just running around the foothills and twisties and 41 when I do a mix of highway and state routes.
Old Aug 4, 2010 | 01:29 PM
  #32
Ohiobellboy's Avatar
Ohiobellboy
02 Ultra
88" with EFI and SE slip on's and 5 speed
Mostly highway during the week I get 38mpg and that's around 75mph.
Old Aug 4, 2010 | 02:55 PM
  #33
The Old Man's Avatar
The Old Man
I have a bone stock 08 EGC...I see 40 maybe 42 on a trip. A low in the high 30's. I figure 54 is off a cliff in neutral!!!
Old Aug 4, 2010 | 03:00 PM
  #34
RFG7680's Avatar
RFG7680
Mines an 08. Stage 1 ac. Rinehart 2-1. pcv set up to run rich to stay cool. But will lean out to stock AFR at 75mph.
In the last 4083 miles I averaged 41.33 mpg. I keep a log on my iPhone.
Old Aug 4, 2010 | 06:07 PM
  #35
MNPGRider's Avatar
MNPGRider
My mileage is in my signature. I have found that any speed over 60, and a strong head on or cross wind, will affect it dramatically.
Also, running non-oxygenated gas when I can find it, rather than 10% ethanol, will add about 2 mpg.
Old Aug 4, 2010 | 06:22 PM
  #36
will2002's Avatar
will2002
I seldom get north of 40 mpg. Usually 38-39, ridin' 70+ mph.
Old Aug 4, 2010 | 06:57 PM
  #37
KutenFLHX's Avatar
KutenFLHX
40-42 average with mostly city driving.
Old Aug 4, 2010 | 07:26 PM
  #38
MNPGRider's Avatar
MNPGRider
Originally Posted by ncdan
i just did an experiment on this same subject.I have an 03 eg with 510 ss cams,stage one air cleaner system, otherwise stock. I made 3 200 mile trips in a row to the same location, on the same roads. Its a fact for my bike that the closer to 3000 rpms I ride the worse millage I get. At 70 mph I get around 38 mpg, at 65 mph I get 40-42, and at 60 mph I get 44-46. I even filled up at the same gas stations.
I would say that's more of an effect of wind resistance than rpms. Try riding at 60 mph in a gear that turns 3,000 rpm's at that speed and compare your mileage.
Many Harley riders are lugging their engines, especially in the six speed tranny. Mark your throttle position and see how far you have to turn it in a higher gear/lower rpms, vs a lower gear/ higher rpm's. You may be surprised at how much more throttle you have to give it to maintain speed at a lower rpm in top gear.
Old Aug 4, 2010 | 08:39 PM
  #39
nvsteve's Avatar
nvsteve
That's a very good point. I've tested what you've said and it is correct. Up to about 70mph, maybe a bit less, it's better to stay in 5th gear. It has alot to do with throttle position.
Old Aug 4, 2010 | 08:54 PM
  #40
jmorganroadglide's Avatar
jmorganroadglide
Big Kahuna HDF Member
I get 36-38 mpg, but we ride loaded and 80mph. I guess the numbers would be better in kpg.
