99 Ultra-Audio setup?
Old Aug 4, 2010 | 06:56 PM
sr_smyth's Avatar
sr_smyth
Default 99 Ultra-Audio setup?
Anyone have a link to share that shows how to set up the Vox/Intercom/CB setup on a 99 Ultra with OE cassette player? I bought the HD owners manual and its not in there and its not in the Clymer either-The Harley owners manual refers you to an HD "audio supplement" for information.
Any idea if this is available online anywhere?
Also, my RH mode/Channel select / VOX button only works in the down direction-won't go back up-any suggestions as to a quick easy fix?
Cheers and happy trails
Old Aug 5, 2010 | 10:57 AM
ZUTEDUFF's Avatar
ZUTEDUFF
SR.
Got the same problem,, just bought this 2000 ultra classic but didn't have owner's manual. When i got the owner's manual, found out you have to buy the Preminum Sound system manual to find out about the workings of the system...Just haven't let go of the 20 buck yet to get one..... I haven't found anything on the web as far as these radio manuals.
good luck......
Old Sep 27, 2010 | 04:01 PM
tomlescal's Avatar
tomlescal
turn Intercom switch on should show VOX on the radio display.then Mode switch on Rihgt handlebar,up to increase sensitivity and down to decrease.Display on radio should show numbers,book says good place to start is 7 or 8.Intercom volume is the same as radio volume.To exit press mode select 1 time.If more adjust ment is needed push the intercom switch forward to enter set-up mode. Try this see if it help you out.
Tom
sixgun95
Apr 8, 2021 11:38 AM
grows
Jan 13, 2010 08:59 PM
HDJIM1158
Mar 15, 2009 11:05 AM
rsofa
Oct 14, 2007 12:11 PM
jcc/tx
Dec 5, 2004 02:35 PM
