starter issue
Old Aug 8, 2010 | 07:14 AM
jrdfatboy's Avatar
jrdfatboy
Default starter issue
Anyone else having this issue? We put on 300 mi. yesterday, out of about 4 or 5 stops, when I went to start my 07 FLHX the starter does not engage or the gears clash, it happened twice. It makes one hell of a lot of racket, does not sound good. Do I need a new starter or something else. It has been doing it all summer, when the bike is cold or warmed up. Any ideas, Thanks
Old Aug 8, 2010 | 09:30 AM
head's Avatar
head
sounds like the starter drive clutch internally. they can be replaced instead of the complete starter motor.
head
Old Aug 8, 2010 | 10:11 AM
ultraclassic03's Avatar
ultraclassic03
Double check all your electrical connections. Sometimes you wont get the full cranking amps with low battery or loose connections,
Old Aug 8, 2010 | 12:11 PM
steve 55's Avatar
steve 55
Make sure your starter bolts are not coming loose. I had starter problems 2 years ago on a trip to N. Carolina. turns out The factory didnt put lock tight on the bolts and they backed out after a few thousand miles. No cost to me everything was under warranty just a big PITA...
Old Aug 8, 2010 | 12:23 PM
mongomark's Avatar
mongomark
Same thing happened to me, loose starter bolts.
Old Aug 8, 2010 | 12:30 PM
jimski's Avatar
jimski
Check out this service bulletin: http://www.box.net/shared/ma1aimen3a
Old Aug 8, 2010 | 12:39 PM
Captain Itch's Avatar
Captain Itch
Sponsor
Check out all of the above...and you may want to look for missing teeth on your ring gear..
__________________
www.Captain-Itch.com
Old Aug 10, 2010 | 08:57 PM
jrdfatboy's Avatar
jrdfatboy
Thanks guys, I'll check it out
Old Aug 10, 2010 | 10:39 PM
Harleyboyddk's Avatar
Harleyboyddk
Hopefully it's the starter bolts. If it was the starter clutch the starter would spin without turning the motor over. If the starter gears sound like they're clashing, the starter drive gear may need replacement. I had a starter drive gear rounded (worn) and the teeth could not engage the ring gear. Made big noise. If not the starter bolts, you're starter is repairable. The starter bolts are grade 8, and I don't reuse grade 8 bolts. The new factory bolts came with thread locker already applied. There's the option of using the high-torque starter as well. Edit- Just saw the service bulletin- looks like the most promising answer.
Summers420us
EVO
30
Feb 22, 2023 03:10 PM
watindes
EVO
Sep 29, 2013 10:48 AM
lebert
Aug 7, 2010 07:03 AM
EasyJoe
Aug 22, 2007 11:06 PM
DGlide04
Aug 26, 2006 07:51 PM
