Installing Grips on Road Glide
Old Aug 11, 2010 | 12:03 AM
sanlyn's Avatar
sanlyn
Default Installing Grips on Road Glide
I'm missing something here. I was going to replace the grips on my 2010 Road Glide Custom, and I removed the two screws on the control, but couldn't pull it apart. Didn't have this problem with the Dyna ... is there something else holding it together? I can see the electronic throttle is different from the set up on the Dyna, but the instructions for the Grips (for the Touring bike) didn't give any other clues. What am I missing?
Old Aug 11, 2010 | 02:00 AM
Sancho's Avatar
Sancho
You have to seperate the upper and lower half of the switch housing to slide the throttle side grip off. Then just slide the new one on.
Old Aug 11, 2010 | 05:28 AM
woosh's Avatar
woosh
On my Street Glide I had to also loosen the two bolts for the brake and clutch lever assemblies.
Old Aug 11, 2010 | 07:32 AM
sanlyn's Avatar
sanlyn
I removed the two Torx bolts, and the top half of the assembly would come up, but couldn't get the bottom portion of the assembly to budge.
Old Aug 11, 2010 | 07:40 AM
Jags93's Avatar
Jags93
I believe there is a note in the service manual on this. Probably for the little locating tab on the top half. Do this and they should come off
Old Aug 11, 2010 | 07:54 AM
Deuce Bigelow's Avatar
Deuce Bigelow
if it's the stock rubber grip on the left side, you will need to cut it off after you remove the switch housing... it's glued on.
the right side will just slide off after you remove the switch housing..
Old Aug 11, 2010 | 08:02 AM
sanlyn's Avatar
sanlyn
Just bought the bike ... have the manual for the Dyna I used to have, they didn't have the touring one in stock when I picked the bike up. I'm guessing there's something holding them together (I can see the wire when I lift the top half. What does the manual say about separating them?
The clutch side looks pretty standard ... cut the plastic grip, sand the old glue off, apply new ...
Are there torque settings for replacing the screws? With the plastic housing I don't want to strip.
Old Aug 11, 2010 | 08:16 AM
Deuce Bigelow
the housings are metal... they will just seperate when you get both screws out.
when putting them back together, I just screw them in till they are tight, I don't use a lot of torque.
Old Aug 11, 2010 | 08:39 AM
rogerfromco's Avatar
rogerfromco
Hope these help.
Attached Thumbnails Installing Grips on Road Glide-p1010196.jpg   Installing Grips on Road Glide-p1010197.jpg   Installing Grips on Road Glide-p1010198.jpg   Installing Grips on Road Glide-p1010200.jpg   Installing Grips on Road Glide-p1010201.jpg
alrosse
2014-2024 Touring Models
Feb 22, 2015 07:40 PM
harleylay
May 20, 2012 08:37 AM
mike_oh
Apr 15, 2012 10:11 PM
dragon_fly121
Oct 3, 2011 11:23 AM
elauee1
May 14, 2011 11:21 AM
