Problem with stage I, input please
Old Aug 13, 2010 | 01:10 AM
jtomhd's Avatar
jtomhd
Default I know EPA wants AFR around 14.7,
but where should it really be to make bike run happy and cool? Another few questions: will a torque cam make the bike run cooler overall? I've read conflicting stuff, like some guy had a 255 in his bike and he had compression release problems, pinging (duh, CR) but if I don't mess with the heads my understanding is that 255 likes stock compression?
I need a tech book on the TC96 and all its secrets will be revealed.
Old Aug 13, 2010 | 01:16 AM
JCleary's Avatar
JCleary
Originally Posted by Then Came Bronson
Couple of questions...
I'm assuming that your monster rounds are Vance & Hines. What is your headpipe? If you're running a stock headpipe with the Cat, shitcan it for some Vance & Hines Power Duals or True Duals. While not cheap, they are a perfect match for your monster rounds.
Next, you need some kind of fuel management system on your scoot. V&H Fuelpak will do the trick, and is very easy to install. If you do these two things, your bike will run a whole lot better and cooler.
The dealer download is bullshit, and it's too bad you got talked into it. Those guys will do anything for a buck.
NO IT WONT!!
Don't throw money away on a Fuel Pak. At the very least get a Fuelmoto PCIII or PCV (Power commander). The Fuel Pak gives you no adjustability. You have to ask Vance and Hines for codes to program the box. You have no idea what the heck they're doing with fueling and timing.
Try and take a Fuel Pak to a dyno tuner and ask him to tune it. Not happening.
At least with a real fueling device, like a Power Commander, Mastertune, SERT, SEST, Thundermax, etc., you can actually tune the bike properly for the modifications and get your AFR where you want it.
It sounds to me like your bike is running a bit lean. An easy way to check is to put your stock air cleaner back on and run it. If it pulls well, you know you're too lean.
Old Aug 13, 2010 | 03:29 AM
Then Came Bronson's Avatar
Then Came Bronson
Originally Posted by JCleary
NO IT WONT!!
With the setup that this guy has (a basic stage one), he doesn't need a Power Commander or a Mastertune, or any of that other bullshit. A V&H Fuelpak will work just fine. If he plans on taking it up to a 103 inch, with ported heads, cams, and a high compression ratio, I would agree with you. With a basic stage one, he doesn't need a dyno tune either.
Vance and Hines has the exact map that he would need with power duals, monster rounds, an Arlen Ness Big Sucker, and a basic 96 inch engine. Anything else is just overkill.
coconl
Feb 3, 2010 02:44 PM
MikeTra
Sep 19, 2007 12:58 PM
dlongo8241
Sep 17, 2007 09:45 PM
waterman7474
Nov 21, 2006 12:52 AM
BVBOB
Exhaust System Topics
Apr 9, 2006 10:46 PM
