ACC switch wiring?
Old Aug 12, 2010 | 07:30 PM
jimsuver's Avatar
jimsuver
Default ACC switch wiring?
I have added a factory ACC switch from the battery to my lighter socket, so it can be hot or on when the bike is not. I ran a fused wire from the battery to the the switch and the lighter orange wire and to ground with the black wire. I have not done anything with the other orange wire. Now if I turn on the switch the green light does not come on unless I plug my phone charger in, and then it flashes as the phone charges. Do I need to use both orange wires to make the green light stay on when the switch is on? Thanks for any help on this!
Old Aug 12, 2010 | 08:07 PM
jimsuver's Avatar
jimsuver
I should add that I unpluged the factory lighter wires.
Old Aug 12, 2010 | 09:58 PM
ZUTEDUFF's Avatar
ZUTEDUFF
the light is probably not coming on until you plug your charger in because that is when it completes the circuit... unless you just need the light on (which will pull a drain on the battery at all times) i would not worry about it....
Old Aug 13, 2010 | 06:58 PM
jimsuver's Avatar
jimsuver
Also if I turn the switch on the lighter does not heat up or make the green light come on. I may have to ask my dealer about what wire does what on the ACC switch. There is one black and two orange wires.
Rudy046
Feb 2, 2015 10:46 AM
fathog
Feb 25, 2013 02:26 PM
sick_dyna
Jun 22, 2011 04:05 AM
jimsuver
Aug 21, 2010 04:33 AM
tbradley
Oct 2, 2007 01:15 PM
