Neutral light on in all gears...
Old Jun 21, 2011 | 10:09 PM
sick_dyna's Avatar
sick_dyna
Default Neutral light on in all gears...
Has anyone been riding and all of a sudden the neutral like flickers on? And stays on? Either in second, third, fourth, or fifth gear? Latley this has been happening to me, so my question to everyone, is there a neutral switch, and where is it located? What would cause something like to happen?
Old Jun 22, 2011 | 01:15 AM
HemiOrange's Avatar
HemiOrange
Look on the top of your transmission, right under the front inside corner of your battery box. There is a tan wire there that connects to the neutral switch, plus another connector that is a black ground. The tan one goes to your malfuntioning light and also into the turn signal module
Disconnect both the tan and black wires to this switch. Connect an ohmmeter between the posts on the switch. With trans in neutral the ohm meter should read 0. In all gears it should read infinity.
If it doesn't do the above, replace the switch.
If it checks out okay, then check out the two wires leading to it for either improper grounding (black) or chafed wires (tan).
Old Jun 22, 2011 | 01:57 AM
clicker01's Avatar
clicker01
Originally Posted by hemiorange
look on the top of your transmission, right under the front inside corner of your battery box. There is a tan wire that there that connects to the neutral switch, plus another connector that is a black ground. The tan one goes to your malfuntioning light and also into the turn signal module
disconnect both the tan and black wires to this switch. Connect an ohmmeter between the posts on the switch. With trans in neutral the ohm meter should read 0. In all gears it should read infinity.
+1 100%
Old Jun 22, 2011 | 04:05 AM
sick_dyna's Avatar
sick_dyna
Thanks Hemi!!
fathog
Feb 25, 2013 02:26 PM
HDmikie
Jan 7, 2012 07:20 PM
jimsuver
Aug 13, 2010 06:58 PM
schienbein
Aug 27, 2009 01:59 PM
