08 brake calipers
Old Aug 12, 2010 | 08:35 PM
jackinthebox's Avatar
jackinthebox
Default 08 brake calipers
On the brake calipers there are 3 allen heads. 2 on each side and 1 under the screen. What are the torque values for thoses. Yes I have a service manual and looked but cant find it for it. Just found the torque value for the mounting screws that are 12pt 10mm. Thx
Old Aug 12, 2010 | 08:46 PM
2deuce's Avatar
2deuce
The only one you should be dealing with in changing pads is the pad pin;
that's 75-102 in-lbs. pg 1-35
Harleypingman's Avatar
Harleypingman
Those tq. values aren't published because, according to HD, they are not rebuildable. Try a chrome plating shop.
Old Aug 12, 2010 | 09:28 PM
jackinthebox
Thx, I was just asking cause I got some polished caliper bolts to get rid of the stock ones that stick out like a sore thumb with my chrome lowers and they came with the other three bolts too. I just replaced and put them on tight, so I guess that will have to do. I did do the caliper bolts per manual.
Old Aug 12, 2010 | 09:29 PM
jackinthebox
Thanks for the info. Im not rebuilding just replaced them with the polished ones.
Old Aug 12, 2010 | 09:32 PM
Springerfan's Avatar
Springerfan
10.7 ft lbs with locktite.
Daedalus1066
2018+ Softail Models
Apr 22, 2019 10:19 PM
penmaker
2014-2024 Touring Models
13
Jun 24, 2015 11:31 AM
dhellyer08
Apr 24, 2015 09:28 PM
royston
May 31, 2008 02:33 PM
carltex
Dec 26, 2006 07:26 AM
