Trouble lubricating streering head bearings
Old Aug 20, 2010 | 08:21 AM
RidemyEVO's Avatar
RidemyEVO
40-50 pumps , a whole tube , this sounds very not right, sounds like its just filling the neck.
Old Aug 20, 2010 | 08:23 AM
bagga's Avatar
bagga
my 85 has whatever grease was put in the bearings when it was built. no more no less. i have never greased them. never had a problem. my 76, the same thing.
Old Aug 20, 2010 | 09:10 AM
hojones's Avatar
hojones
If you grease the neck bearings as the manual says you will have a mess for a long time to come. Just think about how much real turning and wear these bearings are subject to. Why would you want to fill the steering neck completely up with grease?
Old Aug 20, 2010 | 09:22 AM
Certified Drunk's Avatar
Certified Drunk
I'd like to know if you can feel the difference between the way it came from the factory vs you filling the head tube full of grease. You don't see the dirt bike guys doing this and they ride in a lot worse conditions. ...and to answer my own Question, You wont feel any difference.
Old Aug 20, 2010 | 09:29 AM
All Aces's Avatar
All Aces
In the mannual there are 4 groups a,b,c,d for the amount of swing ranging from just left to right to center for the FLTRX to 3 swing min. and 4 swing max. for the rest of the fairing models.
Old Aug 20, 2010 | 09:35 AM
gmc's Avatar
gmc
Originally Posted by All Aces
did your just take a lot of grease, mine has more comming out around the fitting than going in the fitting.
I put a 45 degree zerk fitting in mine, found I couldn't get the grease fitting on using a 90. Your not getting you grease fitting on straight and tight enough if it's comming back out there.
Kaycee
Dec 13, 2017 05:47 PM
mikebaby
Aug 19, 2011 11:35 AM
RazorFXDB
Aug 29, 2007 06:17 AM
dchoran
Jul 20, 2007 08:58 PM
caperss396
Dec 9, 2006 11:59 AM
