OK, horn is all relocated behind the right saddlebag..........that was the easy part.
Now, I want to remove the rubber horn mount thingy......but I can't remove it. I already destroyed it and tore the rubber apart, now what is left is the back part of it that is threaded into the mount.
I drilled the center of it and tried an easy-out, didn't budge at all.
Going to keep drilling it all the way thru, and see if I can get it that way with a bigger bit after.
I could use a cut off wheel and remove that tab completely, but I want to keep it there to put a skull medallion on to hide the wires and sensors for the TB.
