Horn disconnect
Old Oct 4, 2007 | 07:28 PM
98glider's Avatar
98glider
Default Horn disconnect
How do you take off the horn? The manual doesn't get into this. I tried the big nut infront and the rubber started to twist and the one in the back did not move, maybe reverse thread? any help thanks
Old Oct 4, 2007 | 08:23 PM
WS6 Formula's Avatar
WS6 Formula
Default RE: Horn disconnect
Hold the horn as you loosen the nut.If your trying to take off the rubber mount, jam two nuts together on the stud, then use the nut to loosing the mount. The rubber mount will twist quite a bit before it breaks loose.
Old Oct 4, 2007 | 08:29 PM
Bobber S's Avatar
Bobber S
It is not a reverse thread. Turn the horn cover bolt counter clockwise while holding on to the horn cover . This should stop the rubber mount from twisting. Once you get the horn cover off you can remove the horn but you will need a 10mm wrench, and since its not a standard sizenutI figure horn must be made in Japan or China.
Old Oct 4, 2007 | 09:19 PM
DougsDyna's Avatar
DougsDyna
60 mph, drop it on the left side............... This should remove the horn.
Sorry, just had to say it.
DougJ
Old Oct 4, 2007 | 10:07 PM
blavis's Avatar
blavis
ORIGINAL: DougsDyna
DougJ
hahahaha, i'll try it tom after work!
Old Oct 5, 2007 | 11:25 AM
98glider's Avatar
98glider
The rubber keeps twisting. I 'm going to have to get a good twist to break loose the rubber
Old Oct 5, 2007 | 11:39 AM
Sammi's Avatar
Sammi
Hold the horn with one hand and use the wrench with the other.
It's a bitch but it does come off.
Sammi
Old Oct 5, 2007 | 02:07 PM
WS6 Formula
ORIGINAL: 98glider
I had the same problem and thought the rubber was going to rip apart, but it eventually broke loose.
sanman4ever
Sep 4, 2017 05:16 PM
Doc o
Jul 10, 2012 04:50 PM
steelerdude1
Jul 14, 2011 02:32 PM
wildog57
Jan 31, 2010 04:03 PM
tslonige
Sep 26, 2009 08:44 PM
