Jackpot head pipes
Old Sep 23, 2011 | 03:31 PM
  #31
DHubbs's Avatar
DHubbs
I installed the F/M Jackpot 2/1/2 on my 2010 Ultra Classic. I used the existing gaskets just as they recomended, had no problems. I will admit I did make a call to them to ask about it because the fit did not look right, but it works fine. The installation is very simple, should not take more than a couple hours. You will need no heat shield extensions, dont know where that came from. You will notice alot less heat on your right leg. I dont believe your oil temp will change much, get a oil cooler for that. You will love the way they sound, and no they will not have a Cat. in them. I could tell a difference in the performance right away. I believe my bike did go a little lean after installing them, so I did have it tuned again. I already had a SERT stage 1 tune on it.
GalvTexGuy
Apr 25, 2021 04:17 PM
sixguns
2014-2024 Touring Models
Aug 24, 2014 04:45 PM
Flying low
May 29, 2014 06:35 AM
TheMurf
Aug 25, 2011 02:03 AM
Professor
Jul 22, 2010 06:25 PM
