Chrome Display Stand Help
Old Aug 21, 2010 | 09:22 AM
AlleyKatt's Avatar
AlleyKatt
Default Chrome Display Stand Help
I picked up a used Chrome Display Stand. I couldn't get it over the regulator bolts due to the leg angle. I loosened the cap screw opposite the grease zert thinking I could get a little slack in the legs. I heard a loud pop and all tension was gone. Can I replace the spring inside or am I screwed? Called the local dealer and they had no clue. Any help would be appreciated.
Old Aug 21, 2010 | 08:26 PM
ucommbxny's Avatar
ucommbxny
never had a display stand but from what you stated you don't have anything to loose. remove the bolt there might be a tab that the spring attaches to and when you tighten the bolt in place it puts tension on the spring. or something to that effect
Old Apr 29, 2013 | 07:36 PM
Hermanator's Avatar
Hermanator
I have had the same problem when the screw came loose the spring came loose we have had the stand in our vice and cant get the spring to reset... Please Help?
Old Apr 29, 2013 | 07:43 PM
Uncle Larry's Avatar
Uncle Larry
I've never seen anything for directions for servicing the stand. Here's the pdf for installation. http://www.harley-davidson.com/en_US...ts/-J00545.pdf
Old Apr 29, 2013 | 07:53 PM
Hermanator's Avatar
Hermanator
Uncle Larry I have this Directions however no mention on the inner spring tension thanks
NMNSG08
Feb 22, 2016 11:50 PM
Hermanator
Apr 28, 2013 09:19 AM
langlois1
Jun 27, 2009 08:29 AM
kevinhdy
Jul 11, 2008 08:44 AM
DGlide04
Aug 17, 2006 10:35 AM
