Torn rotator cuff and handle Bars
Old Aug 24, 2010 | 05:07 PM
Texas Rapier's Avatar
Texas Rapier
Since I have 12" bars on the bike at this time, will there be a problem with the extra length of cables and wires.....
I have the Heritage style bar and according to the HD catalog they are a 12 inch rise.
If the high is a problem, before you do anything else you may want to try rotating the bars towards you. Less reach, less height, bent elbows, takes the pressure of your shoulders.
if your not using one you may also want to consider a riders back rest. The back rest will support your body weight and take some load off your arms keeping your body upright.
Old Aug 24, 2010 | 05:41 PM
RaceFace's Avatar
RaceFace
I just had my surgery 2 months ago and feel issues with stock RK bars. I'm 6'4" and have pretty long arms. I ended up buying beach bars, but I haven't put them on yet. My physical therapy team swears that they can get me in tip top shape and it won't matter which bars I run. We'll see.
Old Aug 24, 2010 | 05:44 PM
fatboyNick's Avatar
fatboyNick
would these be the correct ones to find?
HERITAGE SPRINGER FLSTS
or is it another Heritage bar?
Old Aug 24, 2010 | 05:47 PM
fatboyNick's Avatar
fatboyNick
12" also, wow, I need to look into this a little deeper, I will also stop at the stealer and look at what they have in stock.
Old Aug 24, 2010 | 06:21 PM
lewain's Avatar
lewain
Originally Posted by ddm502001
Look at Wild 1 web site, I chose the 518's as I have bad shoulders, works great for me but they are low/low.
Any wiring, brake line, or clutch cable change or wiring extension needed?
Old Aug 24, 2010 | 06:46 PM
Texas Rapier
Heritage Style bars P/N 56902-08
Tip to Tip 30.74
Base Width 11.5
Pull-Back 5.00
knurl Center to Center 3.14
Rise Tip To Base 12.00
Chrome High Handle bars p/n 56180-08
Tip to Tip 30.00
Base Width 13.75
Pull-Back 9.00
Rise Tip To Base 9.50
Reduced Reach handlebars p/n56166-08
Tip to Tip 32.00
Base Width 13.00
Pull-Back 5.50
Rise Tip To Base 11.25
Road King Handlebars P/N56941-09
Tip to Tip 34.00
Base Width 11.50
Pull-Back 8.00
knurl Center to Center 4.74
Rise Tip To Base 4.00
Just some number to compair.
Old Aug 24, 2010 | 09:00 PM
nytryder's Avatar
nytryder
I had the same surgery 2 1/2 yrs ago. I ride a lot but am real happy to have cruise control. I have a set of RK Police bars. Hope this helps.
Old Aug 24, 2010 | 09:15 PM
Texas Rapier
The Police bars are usually Heritage Style bars
Old Aug 24, 2010 | 09:42 PM
KutenFLHX's Avatar
KutenFLHX
Believe me, physical therapy will get your arm moving again. I never thought I would get as much range as I did after the accident and had a plate put in my arm. Still gets a little better every week. Just takes time and persistence.
Old Aug 24, 2010 | 10:10 PM
1931jamesw's Avatar
1931jamesw
Get some beach bars.
