Streamliner Passenger Floorboards Install?
Old Aug 24, 2010 | 04:06 PM
Kg6kjs's Avatar
Kg6kjs
Stage IV
Default Streamliner Passenger Floorboards Install?
I am sorry if this has been brought up before. I searched with no luck. I bought the Streamliner Passenger Floorboards I stall was easy untill, I got to the insert rubber portion. I am having trouble pressing the insert into the floor pan. I can get one side pushed in but not the outer side. Is there a trick to getting the insert rubber to plug in? Thank You
Old Aug 24, 2010 | 04:16 PM
petemac's Avatar
petemac
Put some dish soap on the rubber and use needle nose pliers to pull from the other side.
Old Aug 24, 2010 | 05:00 PM
Kg6kjs's Avatar
Kg6kjs
Stage IV
I will Try soap, But I there isnt any holes under floor pan to pull through. So I can only get half the rubber to push in.
Old Aug 24, 2010 | 05:04 PM
petemac's Avatar
petemac
It's been a while since I did mine but I believe the instructions called for drilling a couple of holes. Check your instructions.
Old Aug 24, 2010 | 05:08 PM
petemac's Avatar
petemac
Scratch that last thought on drilling the holes, I was thinking of the rear floorboard covers.
Old Aug 24, 2010 | 05:14 PM
petemac's Avatar
petemac
Just checked the instructions online....here's what is says and the pdf.
http://www.harley-davidson.com/en_US...ts/-J03321.pdf
Footboard Insert Installation
3.
ALL applications: Center the two footboard pivot pins.
4. Use soapy water to moisten the rubber dowel pins and
pivot pin slots on the bottom of the new footboard insert.
5. Place the insert into position with the rubber dowel pins
mating the holes in the footboard pan. Firmly press the
insert into the footboard until the dowel pins pop into place.
6. Fold the passenger floorboard UP and tighten the setscrew
to secure the insert.
7. Repeat Steps 3 through 6 for the opposite footboard.
Old Aug 24, 2010 | 05:15 PM
SBW Cycles's Avatar
SBW Cycles
I just installed a set for a guy. There is a set screw P/N 3341 that screws into the side of the floorboard pan.
Old Aug 24, 2010 | 05:27 PM
AnotherBlackSG's Avatar
AnotherBlackSG
Don't need any "holes". I just SPIT on the rubber and wiggled 'em down into the little nubs. The way they fit down in there seemed a little chintzy & un-secure to me, but once you get them on they work great and stay in place!
Old Aug 24, 2010 | 06:25 PM
jasnusc's Avatar
jasnusc
I bought a set and returned them because of that same reason. They seemed really crappy as far as the design goes.
I've looked at several on bikes since and they all fit like crap too!
I started a post complaining about it months ago.
Old Aug 24, 2010 | 07:49 PM
Kg6kjs's Avatar
Kg6kjs
Stage IV
Ok Thanks for all the help, I tried the splitting the rubber, then pressing the area over the square tabs with a thin blade and that worked. Didnt feel like they lock in very well but the are flat and secure now. Thanks AnotherBlackSG
