engine rebouild 88 or 95 ?
Old Aug 28, 2010 | 10:29 PM
Harleyboyddk's Avatar
Harleyboyddk
I'd like to know if you two are freshening up the top end for the hell of it, or because of motor issues. If the latter how many miles before the problems?
Old Aug 29, 2010 | 03:19 AM
inverse121's Avatar
inverse121
I guess you can say I am doing it for the hell of it.
But I am going 95", bumping compression and adding cams.
Old Aug 29, 2010 | 07:24 AM
Ultraclassic Lou's Avatar
Ultraclassic Lou
4th Gear
It will be a winter project, but I'll send a post upon completion.
Here's the plan;
cam, Andrews TW21
push rods, Andrews Chr-mly
pistons & rings, Wiseco K1717
EFI, PC lll
replace cam chain tensioner
Dyno-Tune
Old Aug 29, 2010 | 07:25 AM
Ultraclassic Lou
4th Gear
that's about $2,500, there goes all my play money
Old Aug 29, 2010 | 08:33 AM
MNPGRider's Avatar
MNPGRider
Here's a great article specifically about what you are asking about.
http://www.americanrider.com/output.cfm?id=1205749
Old Aug 29, 2010 | 08:40 AM
prodrag1320's Avatar
prodrag1320
have your cylinders bored to 3.875 with some SE pistons,same price as going .010 over
Old Aug 29, 2010 | 08:42 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by petemac
I went to a 95" and didn't lose any gas mileage at all.
I did the same and my mileage increased.
All 95's are not the same,all depends on the build.
Old Aug 29, 2010 | 09:53 AM
inverse121's Avatar
inverse121
Here's the plan;
cam, Andrews TW21
EFI, PC lll
Dyno-Tune
Why are you going with the wiseco's? Name? Those things are ridiculously expensive for a mild build and way overkill for a motor you are going to run a TW21 in. I'd buy the screamin eagles for much less. Any reason you need the expensive pushrods or do you just want them? I am all for buying good parts, but you can go a little overboard. For $2500, I'd expect something a little more.
If you say so. I have no idea what a PCIII costs, but everyone around here seems to like them and I know a dyno tune isn't cheap, but worth the money on your fuel injected bike.
Agreed.
rbeamj
Engine Mechanical Topics
14
Mar 26, 2016 07:32 PM
BigMike
Jun 6, 2015 03:47 PM
porterjet
Oct 3, 2011 03:12 PM
jcbpa
Nov 4, 2008 11:26 PM
cnnesseth
Jan 16, 2008 09:55 AM
