07 removeable tour pack problems...
Old Sep 7, 2006 | 09:50 PM
propkillr's Avatar
propkillr
Default 07 removeable tour pack problems...
today i removed the tour pack from my 07 flht. i washed and waxed my bike till it was shining. then i started puting every thing back on. please...what is the secret to placing the tour pack back on? i played with it, i fought it and i even blessed it with fleas, but to no avail. my wise son said that the wise and almost all knowing road warriors on this forum would know! so come on creatures of the road.
when i get the two side bars where they are suppose to be i cant get the quick release to lock back up. help me ole wise ones....
Old Sep 7, 2006 | 10:06 PM
One Black FLHXI's Avatar
One Black FLHXI
Default RE: 07 removeable tour pack problems...
I found that it was best to first remove the hard bags. It is more work but, that is the way the set-up was installed by the dealer.
Old Sep 7, 2006 | 10:31 PM
TJf12's Avatar
TJf12
is it the quick detach tourpack? cause mine was not spaced right from the dealer prep
Old Sep 7, 2006 | 10:38 PM
trmn8r's Avatar
trmn8r
if its bolt on I cant give you any help, only removed mine once... yesterday and then I put on the quick detach hardware, today I put the docking kit on the tourpack and did a test fit on the docking points of the bike... if its got the quick detach setup I still cant give you any tips but can tell you its a darn tight fit! the front docking points I have to squeeze the bracket on the tourpack in together, then to get the rear docking points on I have to pull the brackets on tour pack apart spreading them a bit... Just put it on stood back admired my work then took it back off... geesh feel like I been in a fight trying to get it on. I know this probably wasnt any help, but its my story and I'm stickin t it.
Old Sep 7, 2006 | 10:44 PM
ragingbull's Avatar
ragingbull
I have to remove the side bags first to get the tourpak on easier....
Old Sep 8, 2006 | 12:23 AM
Harleypingman's Avatar
Harleypingman
My tour pack goes on pretty easily if I get the front rack mounting points into the circular receivers in the docking hardware. Then I just rest the moveable parts on rear docking points momentarily while I line of the detachable latches. Once they are lined up, the box just sort of sets down on the rear docking point.
If you are having difficulty, get a hold of the installation instructions for the docking hardware and check that the docking stuff has been installed correctly. HTH.
Old Sep 8, 2006 | 11:10 AM
hillbilly64's Avatar
hillbilly64
Hmmm something is not on right, I never have to remove my bags to install or remove my tourpack. On the rear docking point on the bike there are two holes, I used the most forward one, not sure what the rear one is for.
Old Sep 8, 2006 | 11:20 AM
sleepneagle's Avatar
sleepneagle
OK, first make sure you didn't accidently bent the bracket "C" ends in front. Slide the tour pack on and make sure the "C" ends are seated. The lock bracket end needs to be seated on the bushing with the bushing pushing the releas button up. Sometimes you have to push from the side to seat the lock mechanism. Once seated the lock will rotate to the locking postion. Saddle bags do not have to come off.
Two Lane Tramp
2014-2024 Touring Models
Jul 3, 2017 04:10 PM
RCinLaveen
Aug 27, 2010 10:49 AM
Buszzbait
Jun 15, 2010 08:12 AM
GaryP
Jan 28, 2009 01:11 PM
shortleg
Jan 27, 2008 09:47 AM
