Engine/Primary/Trans OIL Question?
Might not have had anything to do with oil, but worthy of mention.
Also,..... amsoils own website does not recommend extending the intervals on motors with any modifications.
Pretty much makes it no better than dino oil in my case. Not cost effective with the shorty intervals.
Primary: Most any fossil engine oil, preferably the cheaper varieties without friction modifiers. ATF and HD Formula+ are also fine, but the latter is obscenely expensive at $8/qt.
Tranny: Gear oil, synthetic or non-synthetic. Pick your viscosity, but the thicker varieties will run a bit smoother with reduced clunkiness. (If "clunkiness" isn't a word, it should be in the HD world.)
Just trying to get your statement in perspective.... What do you consider "extended drain"? 5000, 7500, 10000? How many miles do you go between changes?
I doubt you will find any mainstream oil that recommends extended drain intervals on modified engines either. They (any oil manufacturer) can't test all modifications to go out on that legal limb. I see Redline just says "extended drain intervals over other brands" and leaves it at that. Wonder what they mean by "extended"?
About the "toast" Evo... it's doubtful that the brand of oil caused the failure don't you think? A more likely scenario would be a minor manufacturing defect, assembly issues, abuse (overheating, lack of routine maintenance, burnouts, whatever) than the actual oil causing the failure. It just as easily could have failed using Brand x. I know all those engines that have "grenaded" have not all used the same brand oil. But then again, WTFDIK?
From Mobil's website;
"Mobil 1 V-Twin 20W-50 is recommended for four-cycle motorcycles that specify the use of a 20W-50 engine oil."
and
"Mobil 1 15W-50 fully synthetic motor oil exceeds warranty requirements for gasoline engines where an API certified oil is specified"
