Fix for less than satisfactory amp set-up
Old Sep 5, 2010 | 04:14 PM
angelrod's Avatar
angelrod
alpine pdx amps 150- 4. I promise you it will rock your soul
Old Sep 5, 2010 | 08:17 PM
davessworks's Avatar
davessworks
Originally Posted by HarleyGoodies
ok... bought one. now what? does it come with instructions?
Yup - instructions included. For some reason mine had the adjustable pots turned all the way up. I suggest you dial them back before powering up. Install is simple enough. Simply run the stock speaker outputs into the wires as directed. To do this you may decide to buy 2 x 3/16" male crimp connectors and 2 x 1/4" male crimp connectors. The smaller size are for the +ve wires, larger for the negative. The hi lo has 2 other brown wires for ground but you will not use these. You will also need a short rca to rca stereo cable. Everything else should be self explanatory.
JNM3
Audio Systems
19
Apr 26, 2018 02:00 PM
bc73
Audio Systems
Apr 27, 2017 06:16 PM
DeputyLoud
Audio Systems
32
Jun 20, 2016 07:02 AM
Angelsbass
Audio Systems
45
Mar 31, 2016 10:46 AM
BrysZ
Feb 1, 2015 04:02 AM
