I got a 1995 electra glide last week cant find a primary drain plug, also does any one know how much oil goes in the tranny and primary. found tranny fill but not sure where to fill the primary. Any help would b greatley appreciated.
There is a magnetic hex head drain plug in the 6 o'clock position directly below the derby cover (round clutch inspection cover). The primary is filled through that derby cover and requires 38-44 oz. Fill the primary with the bike upright (not on the side stand) until the level comes up to the metal ring on the clutch pack. If you haven't done this before find someone who has and have them show you what is needed. ATF works great in the primary.
Don't forget to inspect and/or adjust the primary chain adjuster behind that other funny shaped inspection cover in the center of the outer primary cover. It should have 5/8"-7/8" of slack cold (as opposed to hot 3/8"-5/8").
The transmission takes 20-24 oz. Put 20 oz. in and check the dipstick. Add more until the full mark is reached. Any GL5 - 70/80 or 75/90 gear lube really smooths out the Evo gearbox.
Good luck finding a Service Manual. If you go to the Evo section of this forum you might just get lucky.
