Road glide oil change question
Old Jul 12, 2009 | 05:11 PM
clayman's Avatar
clayman
Default Road glide oil change question
I have searched and cant find the info i need so im asking for some help. I just got the bike yesterday but dont have a manual yet. I have been doing all my servicing on my dyna and other bikes. I have drained the engine and trans but dont see a drain plug for the primary.Do the primary and engine share the same oil? Its an 05
Thanks
Old Jul 12, 2009 | 05:20 PM
boogiewithtuck's Avatar
boogiewithtuck
The primary has it's own supply of fluid - look for a plug at the base of the primary case, just below and to the rear of the outer primary cover.
Old Jul 12, 2009 | 05:32 PM
SPARKY01's Avatar
SPARKY01
Default oil change
ditto
Old Jul 12, 2009 | 05:51 PM
Sharknose's Avatar
Sharknose
Here's everything you need: https://www.hdforums.com/forum/5027544-post2.html
Note that there's a second primary drain shown that you open with a 1/4" allen.
Old Jul 12, 2009 | 09:24 PM
emwolb's Avatar
emwolb
the 05 primary plug is well hidden. i did an oil change on a friends 05 roadking. it's not underneath the lowest part of the bottom of the primary. the plug actually is at the lowest part of the primary cover right below the derby cover. it uses a smaller o ring than which you use for your engine oil and transmission oil drain plugs. the plug is sorta small, and it is between your two lowest primary screws, it points out toward the left of the bike rather than pointing down like the newer models. it's pretty well disguised as another primary screw. but it's there. be sure to replace that small o ring that it takes too. harley parts counter will know exactly the one you need.
Old Jul 12, 2009 | 10:02 PM
clayman's Avatar
clayman
Default Hey thanks
Thanks for the info. yea it is deffinately hidden. Nothing like my dyna at all.
Getting the service manual tomorow :-)
Old Jul 12, 2009 | 10:31 PM
sifularson's Avatar
sifularson
I love that picture every time I see it. LMOA "Sun" "Dead cat"
Old Jul 13, 2009 | 10:41 AM
Sharknose's Avatar
Sharknose
Yep, it's a good one. I printed it out and stuck it inside my service manual way back when. I just referred to it last week when I did a full transfusion.
HoldFast71
Oil Archive (no new posts)
Jul 27, 2012 07:32 PM
lbj
Feb 28, 2012 11:29 PM
kelton3
Apr 28, 2008 06:12 PM
rockchalk
Jun 28, 2007 11:52 PM
pro1955
Nov 29, 2006 03:26 PM
