Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
I am a new (to me) harley owner (93 Electra Glide). I thought I would be smart and change the engine, primary, and trans fluids but I quickly found that I need help. The engine oil I am good with. On the primary crank case and trans...I know the amount of fluids, I just don't know where they go...Can anyone help?
trans should have a fill plug on top, and primary you have to remove the large cover.
Both drain plugs are on the bottom.
I have a Dyna, someone with a Electra Glide better confirm it. You should pick up a service manual for your bike if your going to do your own work. Your owners manual should also cover this.
[sm=biker2.gif] [sm=biker.gif] [sm=biker2.gif] [sm=biker.gif][sm=biker2.gif] [sm=biker.gif] Welcome to the Forums from Louisiana!!!!!!!
[sm=massbounce.gif] [sm=groupwave.gif]
