"lugging"
Old Aug 3, 2011 | 03:11 PM
  #81
sanlyn's Avatar
sanlyn
I generally keep it between 2000 and 3000, although from reading these responses, I'll play with the 2500 to 3000 range.
Old Aug 3, 2011 | 03:24 PM
  #82
texaswiz's Avatar
texaswiz
Originally Posted by BigGdawg
Lugging means it struggles to accelerate, whatever gear you happen to be in. If you dial on the throttle and the bike hesitates you are lugging it. Usually something above 2,000 rpm will be in the power range. It really is not about rpms so much as too tall a gear for the motor to easily accelerate. The HD V-Twin is a low rpm motor but the selected gear has to be appropriate to the speed of the bike. Too high a gear at too low a speed is where I see lugging as a problem. ymmv
That sums it up about as well as anything I have seen.
Old Aug 3, 2011 | 03:27 PM
  #83
kevmiami's Avatar
kevmiami
Originally Posted by Rat1
I spend most of my time above 3000 rpm un less I am cruising on flat level ground at 65 mph.
Lugging the motor or pulling it hard below 2500 rpm, leads to increased cylinder temps which leads to predetination, ping etc.
These motors will happily rev to above 5000 rpm and not even think twice about it. It is much harder on the motor to short shift it keeping below 3000 rpm then it is to let it sing a little.
Agreed, not sure why people say the 96 is a low revving motor. Mine seems happiest and the most fun between 3500 and 4500, with casual cruising around 2800. This makes sense to me; if I look at the base dynos and I see the best torque is in the 3500-4500 range, wouldn't the best torque range be the "easiest" on the motor? Cheers, Kevin
Old Aug 4, 2011 | 09:15 AM
  #84
onaride63's Avatar
onaride63
Originally Posted by nemick
I try to keep my'09 between 2800-3500 rpm. She seems happy there.
same thing for my 05
Old Aug 4, 2011 | 09:56 AM
  #85
beary's Avatar
beary
V twins in general are low revving motors because they produce a higher torque below 4000 rpms compared to the higher revving sport bikes that redline at almost twice the rpms. Next time you see a motorcycle road race or drag race on TV, listen for the differences in V twins compared to the 4 cylinder bikes. You can hear why V twin Ducatis and Harleys are Low revving engines compared to Hondas and Kawasakis.
Lugging is when the pressure on the piston is almost not enough to push the the weight of the bike. It can happen at any rpm. A fully loaded Ultra with big daddy and big momma trying to climb over some of the passes in the Rocky Mountains will likely be lugging below 4000 rpms. If lugging is such a problem below 2500 rpms, how do we go from a stop to cruising speed without lugging?
If you like riding at a lower Rpm but are afraid of lugging, mod your engine a bit to get the low end torque up. Wouldnt take much in most cases.
Beary
Old Aug 4, 2011 | 12:01 PM
  #86
iclick's Avatar
iclick
Originally Posted by LastHalf
Nice looking bike - how do you like those SE255 cams (thinking of getting them with the Stage II kit), is your engine a 96 or up to a 103, and do you have pinging issues? I heard that can be a problem, but they you have some controller that I presume adjusts fuel and timing.
I have a 96 and is stock except for the 255 cams, AC, Jackpot mufflers, and Power Vision. I call it a Stage 1˝. It's a great combo and I have no plans or even a hint of a desire to make further performance upgrades, as the bike runs very well now. I rarely need to apply more than half-throttle at any time, even passing a truck, but YMMV as to what provides adequate power for your needs.
Anyway I`ve been told 2100 rpm is too low and my broken piston were kind of carboned up over by the fracture so I`m wondering if lugging led to carboning up which led to hot spots which led to.....looking for SE255 cams to go with my 103 big bore since mechanics were elbow deep in my engine anyway replacing one 96 ci piston and cylinder!
I don't believe 2100 rpm is going to break a piston, and if it did HD wouldn't specify it as an acceptable RPM to operate. Many ride in this range and you're the first case I've heard about a broken piston, not that it doesn't happen in nature from time to time.
I would definitely do a Stage II while your engine is apart, or at least upgrade the cams. If you go Stage II (103/255) have them also install ACR's, but this isn't necessary with a 96/255 combo.
Old Aug 14, 2011 | 07:21 PM
  #87
LastHalf's Avatar
LastHalf
Yes I asked them to add ACR`s (or manual ones but I assume they have the automatic type) and as far as I know, my Stage II kit is all installed as of this past Tuesday. I`m on the road with the car travelling so gave up waiting on the bike, so I cancelled my New Orleans trip with my wife and took the car elsewhere. Kind of sucks but I still had a good trip. Phoning dealer tomorrow and should be riding it tomorrow night....can`t wait! I presume that combined with the SE perf slipons, V&H fuel pack, 103 ci and 255 cams, it`ll be quite a big improvement and VERY noticeable vs stock, even on an 850 lb electra-glide.
The pinging I had was without a passenger and though it pinged mostly in Yellowstone at elevation, it did elsewhere even when it was pretty flat, so not like it was hugely loaded down (though I`m rather hefty by myself and I did have all bags filled). I don`t know if 2100 rpm did it by itself, but maybe that led to detonation, since it was definately pinging off and on. The damage is pretty much identical to what was described in an excellent article I read on detonation, which was different than what you`d get with pre-ignition. Broken by the ring land and no hole burned or melting, just fractured by the top and middle ring land like a beaver went at it with a passion. I find it strange that it`s so rare, and what did I do so different than these others running 2100 rpm that didn`t break a piston, but I did go about 20,000 km like that in one trip, and didn`t think I had a problem either until this spring. So maybe their bikes are being damaged little by little and they don`t even know it? Only if they`re hearing pinging though. If not then I`d say they have no damage occurring. Hopefully my Stage II with the Fuelpack prevent any future pinging for me.....
Old Aug 14, 2011 | 07:36 PM
  #88
davessworks's Avatar
davessworks
If you can't easily accelerate from the rpm that you are at in the gear that you are at then you are running at too low an rpm.
The concern I have with 6th is when riding with the cruise control on - because you don't have that connection to the response to the throttle that you get when riding without cruise. Be careful then, when approaching a hill, to drop down a gear when using cruise control - or your cruise control may just "lug" your engine for you.
Old Aug 15, 2011 | 07:54 AM
  #89
mac1911's Avatar
mac1911
Very good advice from these replies. I can feel and hear the "sweet spot" between 2800 and 3200. When you bump the throttle, the bike springs to life like it was eagerly waiting for that; below 2500 and it has to work it's way up. It just sounds happier in that upper range. When it's happy, I'm happy.
Old Aug 15, 2011 | 10:26 AM
  #90
iclick's Avatar
iclick
I think you're on the right track, but I might question the Fuelpak on that build. I don't think it has adjustment for ignition advance, and you may need that with the Stage II. I would reconsider and install a tuner that will allow you to adjust this as well as fuel. Adding fuel to the mixture will help any detonation problems but may not be enough.
When I said 2100 wouldn't hurt the bike, I meant the RPM itself as long as you at a steady state and not accelerating heavily or pulling a heavy load up a steep grade. Detonation is quite another issue and it can cause serious damage if bad enough and left unchecked, regardless of the RPM.
