Rotors
Old Sep 9, 2010 | 06:37 AM
AbnMP13's Avatar
AbnMP13
Default Rotors
Will part numbers 44156-00 and 44136-00 fit a 10 Ultra?
Old Sep 9, 2010 | 07:55 AM
dawg's Avatar
dawg
Nope. Bolt pattern is the same, but they are not for the Brembos, they are for the Nissin's up to 2007
Old Sep 9, 2010 | 10:06 AM
grbrown's Avatar
grbrown
Thumbs up
I think you will also find the hole in the centre of the rotor is smaller. In 2002 I think, Harley went from 3/4" wheel bearings to 1" and increased the size of the mounting ring that centres the rotor. Your bike has 25mm bearings, so also check that rotors from 02 later will fit.
Old Sep 9, 2010 | 12:16 PM
AbnMP13's Avatar
AbnMP13
Thanks guys, I was wanting some shiny ones and found those part numbers listed pretty cheap on the web.
Old Sep 9, 2010 | 03:59 PM
bbflhrs's Avatar
bbflhrs
I just took my rotors off my 2007. I didn't see a mounting ring that centers the rotors. Did I miss something?
Old Sep 10, 2010 | 05:12 AM
grbrown's Avatar
grbrown
I've just been out to the garage and checked my 2003 bike. Around the outside of wheel bearing there is thin shallow ring, as part of the hub, that centres the rotor. It is not a tight fit, so when you installed yours it shouldn't have presented any challenge! My 2007 Buell also has one for the rear rotor.
Old Sep 10, 2010 | 05:28 AM
dawg's Avatar
dawg
Those pn#'s were stock numbers so if they were shiny, they were polished. You could polish your own the same way.
AWH
Dec 11, 2017 03:54 PM
brokefootkenny
Jul 24, 2017 08:30 PM
lp77
Oct 11, 2016 02:09 PM
JROCKER
Dec 29, 2012 09:15 PM
09DynaMan
Sep 6, 2009 07:45 AM
