Passing Lamp Replacement
Old Sep 16, 2010 | 01:35 PM
paulies46's Avatar
paulies46
Stage I
Default Passing Lamp Replacement
I had to lay her down last week and bent the passing lamp on the left side of my road king classic. I can't seem to get the lamp off. Will somebody tell me how to get it off?
Old Sep 16, 2010 | 02:18 PM
j1mmy's Avatar
j1mmy
take the turnsignal off, then there is a nut holding the signal mount and passing light togeather
Old Sep 16, 2010 | 02:22 PM
hojones's Avatar
hojones
Two allen head screws holding turn signal have to be removed. Then theres a nut under the assembly that has to be taken off and remove the wire. I usually cut the wire and use a butt end to reconnect instead of fighting the factory terminals. There is a special socket to adjust the lamp but you can also make one.
Old Sep 16, 2010 | 03:02 PM
Nute's Avatar
Nute
I believe it's a 9/16" nut but can't swear to it. Confirm what size the nut is and buy a used one at your local pawn shop. Cut a slot in it and place the wire in the slot when you take the nut off and put the nut back on.
bigblock59
Sep 5, 2016 06:27 AM
Groucho1
Aug 31, 2015 01:58 PM
WetSider
Mar 26, 2013 08:08 AM
FDHOG
Oct 6, 2010 07:02 PM
fattizzi
Jun 23, 2006 05:34 PM
